3 members (Shaffer's1950, Bill Hanlon, Jon G), 125 guests, and 2 robots.
Topics128,139
Posts1,056,454
Members48,441
I'm very new to Stovebolt and to most things mechanical, especially wiring. I am in the process of pulling off the front fenders of my ;47 Chevy pickup so that I can change out the engine. It could really use a new wiring harness at the same time.
Where do I look for a good wiring harness. What is a reasonable price. Tips, helpful hints.
Am I even posting in the right section.
Obvious a novice!
Thanks for your help in advance
I bought the one offered by ClassicParts.com $150 and you can select alternator or generator options. Comes with turn signal wiring and pretty good directions. I have had zero issues with mine. Most options will be plastic coated wire, original cloth is available but in the $600 range. Lots of alternatives from street rod vendors in the $400 range.
Thumbs up for classic parts switched to 12v with alternator, when back in very easily!
Ex Hall Monitor
Ex Hall Monitor
If you choose to go with the original looking harness the two main makers are YNZ Yesterdays Parts and Rhode Island Wiring.
Ronnie Ray,
Welcome to Stovebolt.com
thumbs_up Classic Parts with standard generator or with alternator. Will work with 6v or 12v.
Obvious a novice!
Are you swapping to another 6, or do you want a V8? This will make a difference in what kind of harness you use. I used a Painless harness but mine was a hot rod application.
My 46 GMC on Photobucket
Classic Parts of America
Dennis
