| | | Forums66 Topics128,089 Posts1,056,419 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 22 | I'm very new to Stovebolt and to most things mechanical, especially wiring. I am in the process of pulling off the front fenders of my ;47 Chevy pickup so that I can change out the engine. It could really use a new wiring harness at the same time. Where do I look for a good wiring harness. What is a reasonable price. Tips, helpful hints. Am I even posting in the right section. Obvious a novice! Thanks for your help in advance | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I bought the one offered by ClassicParts.com $150 and you can select alternator or generator options. Comes with turn signal wiring and pretty good directions. I have had zero issues with mine. Most options will be plastic coated wire, original cloth is available but in the $600 range. Lots of alternatives from street rod vendors in the $400 range. | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Thumbs up for classic parts switched to 12v with alternator, when back in very easily!
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you choose to go with the original looking harness the two main makers are YNZ Yesterdays Parts and Rhode Island Wiring.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Ronnie Ray, Welcome to Stovebolt.com  Classic Parts with standard generator or with alternator. Will work with 6v or 12v. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I'm very new to Stovebolt and to most things mechanical, especially wiring. I am in the process of pulling off the front fenders of my ;47 Chevy pickup so that I can change out the engine. It could really use a new wiring harness at the same time. Where do I look for a good wiring harness. What is a reasonable price. Tips, helpful hints. Am I even posting in the right section. Obvious a novice! Thanks for your help in advance Are you swapping to another 6, or do you want a V8? This will make a difference in what kind of harness you use. I used a Painless harness but mine was a hot rod application. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 |
Dennis -there is nothing stronger than the heart of a volunteer-
