4 members (Rick Brown, DadsFirstPickup, Robert Crandall, JakeM), 128 guests, and 1 robot.
Topics128,108
Posts1,056,239
Members48,437
#968825 09/02/2013 11:12 PM
Here's what happens when you glue a '54 3800 to an '88 Jag XJ6 car.
Final Product
We stripped the front and rear axles from the Jag and hauled the carcass to the recyclers. The car was non-running and pretty much trashed.
What's left of Jag XJ6
The I found a '54 frame from a 1/2-ton hydramatic truck from South Dakota. Stripped the stock axles and grafted on the Jag axles.
Jag front end
Jag rear end
Dropped in the 235 from the 3800 and adapted a T5 5-speed from an S-10
235
T5
Pulled the cab and front dog house from the 3800 and installed on 1/2-ton frame:
Old 3800 cab
Found an old '54 short bed and some fenders.
Ugly bed
Get high school kid to clean inside. Wanted to keep outside original, but we stripped inside and installed peel-n-stick fake dynomat and redid seat.
Safety third
Rattle can resto
Putting it all together.
Rebuilt 235: '54 block with '56 848 head
Getting there
New pine bed but kept old metal str... look right with shiny stainless strips.
Before washing with CLR
After washing with CLR
Truck is running great and drives nice. I need to install power steering pump because the Jag rack doesn't like being used manually. It steers, but I'm basically pushing fluid from one side to the other when I turn. It's got disc brakes all around and I'm thinking about upgrading to a power booster. I also want to lower the rear about 2" by raising the top of the shock towers. I was surprised there is enough room to do that with the floor in place in it's original position, but I measured and I've got 2" to play with. I might splurge for airride shocks in the rear so I can drop it really low if I want to.
I'd like to find a '54 bed in the same green as the cab. The orange bed is solid, but looks kind of weird. No plans to paint truck. I like the old look and it cleaned up nicely using CLR and green scotch brite pad.
1954 Chevy 3100
"Jagrolet
More pix on my website
1953 f100 w/ v8
1953 f250 w/ v8
sfeldma #968826 09/02/2013 11:15 PM
All photos of build here:
Build photos of Jag-rolet
1954 Chevy 3100
"Jagrolet
1953 f100 w/ v8
1953 f250 w/ v8
sfeldma #968842 09/03/2013 12:00 AM
R Online: Content
You'd never know by looking that it wasn't totally original. Nice job!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
sfeldma #968920 09/03/2013 9:46 AM
Hey I like what your doing. Nice work.
sfeldma #969571 09/05/2013 8:13 PM
1 Offline
Cool build!
Moderated by  J Lucas
