0 members (),
112
Mod | | | Forums66 Topics128,090 Posts1,056,380 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Are the exhaust bolts and clamps the same for a '38 216 to a '62 235? The spacings really tight between 1 and 2, and 5 and 6 on the inner flange that the others fit on. It looks like a longer bolt would allow clamping on what appears to be an outer flange. If not, is there a kit? Thanks! Tom (getting closer!) | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Not sure what you're asking, exhaust to head bolts of exhaust pipe to header? Clamps? You should use a 235 manifold vs. the 38 for sure, but you could make the 216 work with 235 but not the best set up. Best of luck Jim | | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Sorry about the confusion! Exhaust/intake manifold to head bolts and clamps. Between cylinders 1-2, and 5-6 it's too tight to get a socket in there. Is there a difference in the clamps and washers between 216 and 235? Trying to avoid doing it twice! Thanks! Tom | | | | | Joined: Jul 2002 Posts: 166 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 166 | On my 37 truck with a 56 235, I had to resort to box end wrenches to tighten the manifold bolts you are talking about. It's slow & a real pain but I finally got them tight. | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | On my 37 truck with a 56 235, I had to resort to box end wrenches to tighten the manifold bolts you are talking about. It's slow & a real pain but I finally got them tight. I had to do the same on my 54... it WAS a pain, and tedious. But ya gotta do what ya gotta do. | | |
