2 members (39Master85, JW51), 129 guests, and 4 robots.
Topics128,095
Posts1,056,468
Members48,444
#967843 08/29/2013 2:21 PM
Are the exhaust bolts and clamps the same for a '38 216 to a '62 235? The spacings really tight between 1 and 2, and 5 and 6 on the inner flange that the others fit on. It looks like a longer bolt would allow clamping on what appears to be an outer flange.
If not, is there a kit?
Thanks!
Tom
(getting closer!)
abxtc #967846 08/29/2013 2:25 PM
Not sure what you're asking, exhaust to head bolts of exhaust pipe to header? Clamps? You should use a 235 manifold vs. the 38 for sure, but you could make the 216 work with 235 but not the best set up.
Best of luck
Jim
1946 1/2-Ton Chevy
abxtc #968014 08/30/2013 10:34 AM
Sorry about the confusion! Exhaust/intake manifold to head bolts and clamps. Between cylinders 1-2, and 5-6 it's too tight to get a socket in there. Is there a difference in the clamps and washers between 216 and 235? Trying to avoid doing it twice!
Thanks!
Tom
abxtc #968020 08/30/2013 11:59 AM
On my 37 truck with a 56 235, I had to resort to box end wrenches to tighten the manifold bolts you are talking about. It's slow & a real pain but I finally got them tight.
1937 Chevy pickup
1952 MGTD
I had to do the same on my 54... it WAS a pain, and tedious. But ya gotta do what ya gotta do.
