0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96473 07/25/2006 4:09 AM | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Hi all, I am considering a 12 volt wiper motor conversion for my '54 panel. I have seen prices from $130-$180 in the major catalogues. I don't want to just shop price. Is there anything in particular that I need to know? Or are there any units I should stay away from? Thanks as usual.
All the best, Ted
#96474 07/25/2006 4:24 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are you going to use a factory radio/speaker? If you are, and your truck is a 1954 Chevrolet, I think that there are no aftermarket electric wipers that will mount with the original radio/speaker in place (if you have a GMC, it is no problem). | | |
#96475 07/26/2006 4:24 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have the Newport wiper motor in my '55 1st GMC Panel. I regret not spending the extra for the intermitment function. I had a little trouble getting it adjusted right at first, but once I got everything set its been perfect.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#96476 08/07/2006 11:59 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Gents: Just my .02$ worth. I had a Newport Engineering unit that I installed in another vehicle. Supposedly it was designed as a direct bolt in replacement for the vacuum OEM wipers. Well after hours and hours of work, throwing out the hardware that came with the kit, etc. I finally got it in and working. Yep it worked fine after I finally got it installed, but would I ever buy another Newport Engineering product....No thanks..I'll buy someone elses design.
Bubba
#96477 08/07/2006 2:27 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | actually I don't think there is any other design  there appears to be a "knock off" version of the Newport unit, identified by the lack of a name on, but it's pretty much the same as the one with the Newport name on it - no experience with the AD model, but the Newport unit for the TF years works fine and installs as easy as the OEM optional electric unit Bill | | |
#96478 08/09/2006 3:28 AM | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | The Newport unit I put in my '47 bolted right in, just as the instructions said. It even told where there would be a hole to bolt the bracket on-and it was there, just like it said. Only thing was, I had to move the switch, as it would no longer fit into the original hole. | | |
#96479 08/14/2006 9:06 AM | Joined: Dec 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 92 |
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
