1 members (JW51), 98 guests, and 3 robots.
Topics128,055
Posts1,055,782
Hi all,
I am considering a 12 volt wiper motor conversion for my '54 panel. I have seen prices from $130-$180 in the major catalogues. I don't want to just shop price. Is there anything in particular that I need to know? Or are there any units I should stay away from? Thanks as usual.
All the best, Ted
Are you going to use a factory radio/speaker? If you are, and your truck is a 1954 Chevrolet, I think that there are no aftermarket electric wipers that will mount with the original radio/speaker in place (if you have a GMC, it is no problem).
I have the Newport wiper motor in my '55 1st GMC Panel. I regret not spending the extra for the intermitment function. I had a little trouble getting it adjusted right at first, but once I got everything set its been perfect.
Gents:
Just my .02$ worth.
I had a Newport Engineering unit that I installed in another vehicle. Supposedly it was designed as a direct bolt in replacement for the vacuum OEM wipers. Well after hours and hours of work, throwing out the hardware that came with the kit, etc. I finally got it in and working. Yep it worked fine after I finally got it installed, but would I ever buy another Newport Engineering product....No thanks..I'll buy someone elses design.
Bubba
actually I don't think there is any other design grin there appears to be a "knock off" version of the Newport unit, identified by the lack of a name on, but it's pretty much the same as the one with the Newport name on it - no experience with the AD model, but the Newport unit for the TF years works fine and installs as easy as the OEM optional electric unit
The Newport unit I put in my '47 bolted right in, just as the instructions said. It even told where there would be a hole to bolt the bracket on-and it was there, just like it said.
Only thing was, I had to move the switch, as it would no longer fit into the original hole.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I have had good luck with AFI boat Widshield Wiper Motor
http://cgi.ebay.ca/Outboard-Motor-B...451QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
