8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | When I was first into cars in the late 40's and early 50's just about none had air conditionaing. There was an air deflector that went on the lower pointed end of the vent window and directed air down around the pedals and bottom of the steering column to counter heat coming in around them. I googled air deflector and all offered are for the out side to deflect away rain when the vent is open. Does anyone know if the downward deflectors are still offered? Thank you; Evan
Evan
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Are you looking for what they call "breezies" ? They can be found on ebay. When searching, be sure to include vent in the search. "Original Ad" | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks guys for posting. I have never seen or heard of these. George, thanks for the link. Learn something new today! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jun 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 51 | Very cool! Never knew about these either. Thanks!! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | In the 50's to 60's you could by them in all colors to suit your taste at Pep Boys.
Drew
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I am 67 years old and don't remember ever seeing these. Maybe where I grew up they could not afford them. Very neat!
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | There are 118 vent breezies listed on ebay right now.
Drew
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Never knew about these either?  Anybody have first hand experience using these? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Wow!! You guys get an A+. Never gave doing a search on ebay a thought after coming up short on google. REALLY helps to know what they were called. Thanks; Evan
Evan
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Hot Rod John, Very easy to test to see if they will help; with your vent a little more than halfway open use the flat palm of your hand to direct the air down toward your feet. In my case, with not too good of pedal and column seals, it helped a bunch.
Evan
| | | | | Joined: Jun 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 51 | Seems they are big with the VW crowd...and I heard some positive feedback on them, but never used one myself | | |
