8 members (Otto Skorzeny, Steelonsteel, Gdads51, J Lucas, Peggy M, dt235sd, walter74, klhansen), 127 guests, and 3 robots.
Topics128,036
Posts1,055,454
Members48,422
#963373 08/13/2013 9:14 PM
When I was first into cars in the late 40's and early 50's just about none had air conditionaing. There was an air deflector that went on the lower pointed end of the vent window and directed air down around the pedals and bottom of the steering column to counter heat coming in around them. I googled air deflector and all offered are for the out side to deflect away rain when the vent is open. Does anyone know if the downward deflectors are still offered? Thank you;
Evan
Evan
Are you looking for what they call "breezies" ? They can be found on ebay. When searching, be sure to include vent in the search.
"Original Ad"
coilover #963418 08/13/2013 10:39 PM
Thanks guys for posting. I have never seen or heard of these. George, thanks for the link. Learn something new today!
Ex Hall Monitor
Ex Hall Monitor
Very cool! Never knew about these either. Thanks!!
In the 50's to 60's you could by them in all colors to suit your taste at Pep Boys.
Drew
I am 67 years old and don't remember ever seeing these. Maybe where I grew up they could not afford them. Very neat!
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
There are 118 vent breezies listed on ebay right now.
Drew
Never knew about these either? ohwell
Anybody have first hand experience using these?
Wow!!
You guys get an A+. Never gave doing a search on ebay a thought after coming up short on google. REALLY helps to know what they were called. Thanks;
Evan
Evan
coilover #963723 08/14/2013 10:05 PM
Hot Rod John,
Very easy to test to see if they will help; with your vent a little more than halfway open use the flat palm of your hand to direct the air down toward your feet. In my case, with not too good of pedal and column seals, it helped a bunch.
Evan
Seems they are big with the VW crowd...and I heard some positive feedback on them, but never used one myself
