3 members (panic, baldeagle, 68ironhead), 81 guests, and 4 robots.
Topics128,014
Posts1,055,330
Members48,419
#960828 08/03/2013 4:26 AM
Hi All, I'm not at all having any success with my brakes on my 1950 3100. It has HUCK brakes in front and reg drum in the rear from a 1969 C-10.I replaced a new master cylinder twice and it has all new wheel cylinders and brake shoes and new steel lines and I bled the MC and all the W C several times the correct way from RR to LF and I CANNOT get any pedal , Air bubbles SEEM not to be there , I used a clear hose and a glass bottle. I've never had this happen before, Any help would be very appreciated. Thanks, Bruce[i][/i]
The first thing is to make sure that all the shoes are adjusted up to spec. If they are not you will never get any pedal.
1951 1 Ton Completed
ODSS Lawman
ODSS Lawman
Do you have the proper valving since you have two different type of brakes? You may want to consider changing the Huck to match the rear so this isn't an issue.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Riding in the Passing Lane
Make shure the huck brakes are adjusted up properly. They are tricky to adjust.
1972 Chevy c10 Cheyenne Super
....you said you used a clear hose and a glass bottle. Did you put some brake fluid in the bottle so it would not suck air back into the system?..... I just had to ask!
Ditto to what George said to. My experience with huck or the later bendix is that no matter how good you adjust them, I've always had to go back and do it "one more time".
Good luck. Let us know what you find.... in case we have the same problem later.
