1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 40 | Hi All, I'm not at all having any success with my brakes on my 1950 3100. It has HUCK brakes in front and reg drum in the rear from a 1969 C-10.I replaced a new master cylinder twice and it has all new wheel cylinders and brake shoes and new steel lines and I bled the MC and all the W C several times the correct way from RR to LF and I CANNOT get any pedal , Air bubbles SEEM not to be there , I used a clear hose and a glass bottle. I've never had this happen before, Any help would be very appreciated. Thanks, Bruce[i][/i] | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The first thing is to make sure that all the shoes are adjusted up to spec. If they are not you will never get any pedal. | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Do you have the proper valving since you have two different type of brakes? You may want to consider changing the Huck to match the rear so this isn't an issue.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Make shure the huck brakes are adjusted up properly. They are tricky to adjust. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....you said you used a clear hose and a glass bottle. Did you put some brake fluid in the bottle so it would not suck air back into the system?..... I just had to ask!
Ditto to what George said to. My experience with huck or the later bendix is that no matter how good you adjust them, I've always had to go back and do it "one more time".
Good luck. Let us know what you find.... in case we have the same problem later. | | |
