1 members (Hanks custodian),
103
10
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96073 06/24/2006 4:04 PM | Joined: Apr 2006 Posts: 1 Junior Member | | Junior Member Joined: Apr 2006 Posts: 1 | I have a 1/2ton AD PU. I've only owned this truck for a few months, so I don't have much history on it other than it seems to be a nice and complete restoration including a new cloth covered wiring harness (probably purchased from Jim Carter). The headlights/parking lights/tail lights had been working correctly until I pulled the truck back into the garage last night. When I went to turn off the lights the tail lights stayed on. Further investigation showed that the parking lights worked correctly - on at the mid-pull of the switch and off in the full-out and full in postion, but the headlights do not go on and the tail lights stay on.
It was late when I pulled it in last night, so I haven't done much invenstigation other than what I stated above and pulling the wires at the tail lights to save the battery.
Do I have a short in my head light switch? Any other ideas?
Being that I am new to the hobby I would deeply appreciate any suggestions on what I should be checking out.
Thanks!
Looking for that perfect AD pickup
#96074 06/24/2006 4:41 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might do a search for head lights,etc.. here is one previous post that may or may not help.. here Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#96075 06/24/2006 4:58 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Check the wires on back of the switch.
"It ain't a truck if you can't hose out the cab."
#96076 06/24/2006 5:32 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Don't forget the dimmer switch. Those things can run you nuts. | | |
#96077 06/24/2006 7:25 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Sometimes the contacts inside the switch get a little worn & bent with age. I removed my original switch, bent the tabs on the back and took it apart. I then sanded the contacts a little and bent them in so as to provide a little more contact pressure and it works like new now. The repops are mostly junk so this is a worthwhile task. Run a little sandpaper over the dimmer coil too and she should work good as new. Good Luck  | | |
#96078 07/04/2006 5:44 PM | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Hello, I need a new headlight switch for my 48 1/2 ton. The dimmer post broke off and the masonite back plate is broken also. Are there any after-market switches available that aren't junk?
1948 AD Pickup
#96079 07/04/2006 7:31 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by littlebuddie: Hello, I need a new headlight switch for my 48 1/2 ton. The dimmer post broke off and the masonite back plate is broken also. Are there any after-market switches available that aren't junk? Go here . Put "headlight switch" in the left search box & the year of your truck in the right.
#96080 07/05/2006 1:39 AM | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 |
1948 AD Pickup
