5 members (baldeagle, lumbersawyer, Woodcmiami, BillCollins, 1 invisible), 75 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#96073 06/24/2006 4:04 PM
Junior Member
Junior Member
I have a 1/2ton AD PU. I've only owned this truck for a few months, so I don't have much history on it other than it seems to be a nice and complete restoration including a new cloth covered wiring harness (probably purchased from Jim Carter). The headlights/parking lights/tail lights had been working correctly until I pulled the truck back into the garage last night. When I went to turn off the lights the tail lights stayed on. Further investigation showed that the parking lights worked correctly - on at the mid-pull of the switch and off in the full-out and full in postion, but the headlights do not go on and the tail lights stay on.
It was late when I pulled it in last night, so I haven't done much invenstigation other than what I stated above and pulling the wires at the tail lights to save the battery.
Do I have a short in my head light switch? Any other ideas?
Being that I am new to the hobby I would deeply appreciate any suggestions on what I should be checking out.
Thanks!
Looking for that perfect AD pickup
#96074 06/24/2006 4:41 PM
you might do a search for head lights,etc..
here is one previous post that may or may not help..
here
Redryder pix
My Hotrod
#96075 06/24/2006 4:58 PM
Check the wires on back of the switch.
"It ain't a truck if you can't hose out the cab."
#96076 06/24/2006 5:32 PM
2 Offline
Don't forget the dimmer switch. Those things can run you nuts.
#96077 06/24/2006 7:25 PM
Sometimes the contacts inside the switch get a little worn & bent with age. I removed my original switch, bent the tabs on the back and took it apart. I then sanded the contacts a little and bent them in so as to provide a little more contact pressure and it works like new now. The repops are mostly junk so this is a worthwhile task. Run a little sandpaper over the dimmer coil too and she should work good as new. Good Luck cool
#96078 07/04/2006 5:44 PM
Hello,
I need a new headlight switch for my 48 1/2 ton. The dimmer post broke off and the masonite back plate is broken also. Are there any after-market switches available that aren't junk?
1948 AD Pickup
#96079 07/04/2006 7:31 PM
Ex Hall Monitor
Ex Hall Monitor
Quote
Originally posted by littlebuddie:
Hello,
Go here . Put "headlight switch" in the left search box & the year of your truck in the right.
#96080 07/05/2006 1:39 AM
Thanks Tiny!!
1948 AD Pickup
