1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 1 Moderated | | Moderated Joined: Jun 2013 Posts: 1 | My Dad has a 46 Chevy he did a restoration on in the early 70's . I has sat in his garage for years . I have done al the steps necessary for a start up . Everything is fine , except no spark . It turns over well , all wires look good . I traced backwards from the spark plugs . Found no spark to the coil . Im sure it is something simple Im missing . Any suggestions ? | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Check the points. If you open and close the points with a plastic handled screwdriver, you should get a spark at the coil. If you don't, check the usual things; is there voltage to the points? Are they grounded? Is there a bad wire? Etc., etc. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome to the Stovebolt, kornbwn. You may want to ask this question in the Electrical forum. Paul gives some good advice. Hope it all works out..... let us know what you find so we can all learn together. | | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | Welcome, glad to hear you are bringing the 46 back to life | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome to the forum, I like the 46s. Im sure it is something simple Im missing . I always seem to miss the simple things, hope you can pinpoint it. Leo | | |
