1 members (78buckshot), 64 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
#956295 07/14/2013 10:25 AM
Moderated
Moderated
My Dad has a 46 Chevy he did a restoration on in the early 70's . I has sat in his garage for years . I have done al the steps necessary for a start up . Everything is fine , except no spark . It turns over well , all wires look good . I traced backwards from the spark plugs . Found no spark to the coil . Im sure it is something simple Im missing . Any suggestions ?
kornbwn #956330 07/14/2013 2:41 PM
Red dot, center of chest ...
Check the points. If you open and close the points with a plastic handled screwdriver, you should get a spark at the coil. If you don't, check the usual things; is there voltage to the points? Are they grounded? Is there a bad wire? Etc., etc.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
kornbwn #957753 07/20/2013 10:58 PM
Welcome to the Stovebolt, kornbwn. You may want to ask this question in the Electrical forum. Paul gives some good advice. Hope it all works out..... let us know what you find so we can all learn together.
Welcome, glad to hear you are bringing the 46 back to life
kornbwn #959396 07/27/2013 8:47 PM
Leo Offline
Moderator
Moderator
Welcome to the forum, I like the 46s.
I always seem to miss the simple things, hope you can pinpoint it.
Leo
