| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 30 New Guy | | New Guy Joined: Jul 2013 Posts: 30 | Hi I'm just starting a resto of a 47 1 1/2 ton loadmaster that runs great when I can get enough juice to the starter. Does anyone have a link to a wiring diagram for this truck and a reputable supplier for a replacement harness? This has been far fixed too many times and has shorts or brittle wires everywhere!
Whatever I touch or test seems to break off and I'm flipping out! | | | | | Joined: Mar 2000 Posts: 1,180 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,180 | | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Essentially it is the same as an AD model pickup or one ton except for the wire lenghts to the rear, perhaps the cab cluster lamls, etc. But as for the engine it is the same I'm sure. The wiring harness can be p[urchased at any of the usual vendors such as LMC, etc. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | There was a guy that wanted to build one from scratch. By the time that he bought all of the wiring,connectors,fuse block,etc,he figured it would cost him almost double the price of a new harness.Hope this helps. | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Pay attention to the battery and ground cables too especially if you are using 6 volts. Over the years previous owners would often replace these cables with the lighter gauge 12 volt cables that are unable to carry enough current to turn a 6 volt starter sufficiently. This and dirty connections can be the heart of most 6 volt staring system problems.
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
