0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | I have a stock 59 3600 napco 4x4 and would like to make a few low cost modifications to my truck to get some more horsepower. I was considering changing the camshaft and porting and polishing the head.I would also open up the intake and exhaust manifold to match the gaskets. Any recommendations on what cam I should use?
Another question I have has to deal with the stock differentials. The rearend will need a rebuild or replacement soon and factory replacement parts are not available. I was told a 12 bolt rear from a pre 73 chevrolet 3/4 ton will fit right in. Is that information correct? Any help would be appreciated | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | There are several different grinds of cam available. Check Patricks Another option, which is what I have in mind when I get to building a 235, is using a stock 261 cam. It would be like using an RV cam in a 350. More low end grunt, but still very streetable. Good luck!!
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | JW: I had a 70s rear in my 57 3/4 ton before it was converted to a NAPCO. However, you probably know this, the front & rear differential ratios need to match. | | |
