2 members (Ponchogl, Gdads51), 98 guests, and 3 robots.
Topics128,128
Posts1,056,670
Members48,450
Junior Member
Junior Member
I have a stock 59 3600 napco 4x4 and would like to make a few low cost modifications to my truck to get some more horsepower. I was considering changing the camshaft and porting and polishing the head.I would also open up the intake and exhaust manifold to match the gaskets. Any recommendations on what cam I should use?
Another question I have has to deal with the stock differentials. The rearend will need a rebuild or replacement soon and factory replacement parts are not available. I was told a 12 bolt rear from a pre 73 chevrolet 3/4 ton will fit right in. Is that information correct? Any help would be appreciated
8
8 Offline
There are several different grinds of cam available. Check Patricks Another option, which is what I have in mind when I get to building a 235, is using a stock 261 cam. It would be like using an RV cam in a 350. More low end grunt, but still very streetable. Good luck!! smile
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
JW: I had a 70s rear in my 57 3/4 ton before it was converted to a NAPCO. However, you probably know this, the front & rear differential ratios need to match.
