| | | Forums66 Topics128,188 Posts1,057,329 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jul 2013 Posts: 7 New Guy | | New Guy Joined: Jul 2013 Posts: 7 | So would that make it a 2 ton truck? Are the headlight buckets the same as the 1/2 ton? | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | I don't know whether or not you can tell by the engine, I thought it was by the gvw. 14,000 = 1,5 ton and 16,000=2 ton. Is this correct? Close? | | | | | Joined: Jul 2013 Posts: 7 New Guy | | New Guy Joined: Jul 2013 Posts: 7 | I don't know whether or not you can tell by the engine, I thought it was by the gvw. 14,000 = 1,5 ton and 16,000=2 ton. Is this correct? Close? I know the truck has 20" 5 lug front wheels and I believe 20" 10 lug rears. I can't find any gvw tags or anything on the cab. I'm not even positive of the year. The 1947's I've seen don't have the bucket style headlights that mine has (or should have since they're missing) so do I have a 1946? It has the factory reinforcements riveted to the frame and a 2 speed rear axle The engine serial number is EEA63974I | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | It's either a '46 or an early '47. The info. plate on my '46 is on the cowl under the right-hand hood side panel. That should have the serial # and the GVW stamped on it. Mine is hard to read, but the info. is there. A 6000 series is a 2-ton truck. A 1 1/2 ton is a 4000 series. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | EEA is a code for a 1947 Advance-Design truck. The 1946 trucks sold in 1947 were registered as 1947 trucks but were referred-to by GM as 1946 trucks. 20" 5 lug and 20" 10 lug wheels were used on 4000-6000 series 1947 Advance-Design trucks. What are the widths of the tires (although, incorrect width tires can be mounted on the wheels)? Here are 1946 codes. Is there a metal tag mounted on the cab between the driver's side door hinges? | | | | | Joined: Jul 2013 Posts: 7 New Guy | | New Guy Joined: Jul 2013 Posts: 7 | For the life of me I can not find an actual VIN on the truck itself. I have defreased the cowl, scrubbed it by hand down to clean shiny paint and still can't find a thing. Does anyone have a pic of theirs so I can see where exactly I should be looking?
I checked the door frame too all over. I haven't checked for a rear axle number though. I'll check tonight. Thanks guys! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jul 2004 Posts: 2,995 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,995 | The photos in his first post show what appears to be a '46. | | | | | Joined: Jul 2013 Posts: 7 New Guy | | New Guy Joined: Jul 2013 Posts: 7 | It is definitely a 1946 body style. That's why I'm also asking about the headlight buckets that go on top of the fenders because it didn't come with any. I may never know what year this poor old truck was made  Getting a VIN tag for it and registering this truck is going to be a major pain I can ready tell | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | If it is in fact any early 47, the headlight buckets are obviously the same as a '46 and should be fairly easy to locate. I have heard people in the same situation go out a purchase a junker of the same vintage just to get the vin plate and clean title, maybe even a few parts needed too (headlight buckets??). I am not advising any sort of unlawful activity, I'm just saying, it has been done......Also, when I had my '46 in a million pieces, I never saw any numbers on the frame anywhere. Did they stamp the frames with vin numbers back then? Even if they did and you went to register the truck with a different vin plate would the dmv even know where to look or make the effort? When I register my truck, they took the numbers I had and the title and I was out of there in 15 minutes. I also registered the truck with vintage '46 plates and was surprised how easy the whole process was, especially for the MD. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It would be interesting to see when the block and head were cast. Post the head date casting code and the block date casting code - this might have a 1946 date and will give us more to speculate about. Do you know what model you have; or, do you want help with that? | | | | | Joined: Jul 2013 Posts: 7 New Guy | | New Guy Joined: Jul 2013 Posts: 7 | I'd love as much help as possible with this haha! I will have to finish degreasing the motor later tonight and see what those other codes are. I only looked for the engine serial number which I found and took pics of... [IMG] http://i1164.photobucket.com/albums/q578/John_Haelen/null-7.jpg[/IMG] | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | They had the '47 first and the '47 second series, the first series was the art deco style and the second series was the advanced design | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | He's got either a '46,or an "early"'47,that resembles the '46,like the '55 1st-Series resembles a '54. | | |
