0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Title says it all. Looking for suggestions as to doner.
Les | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Come on guys. I know someone has looked through late seats. What I need should be like what you could use in a '60 - '66 or a '73 - '88 as well.
Les | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Les, I used the bucket seats out of a 03 Chevy Silverado king cab. Electric on he driver seat. Since they sit on my "seat riser" in the panel I did not have to block the seats up or anything. Just bolted them down where I wanted them. They ride good to..... I think its 99-06 that are the same if they will work for you. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | So you are looking for modern bucket seats for a 67-72 truck. DO you want electric, low back, high back, arm rests, built in seat belts.?????????? There are a million of them. See if this is what you are thinking. Probably like what Achip said, I didn't check his. But his application is not 67-72. Width is the first concern. 2002 Silverado in a 1972 Chevy Truck: Pic 1Pic 2
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Thanks all! Now I have someplace to start! I'll be out of town for a while. Achipmunk knows where. Later! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | bartamos is right. The width may make a difference and it depends on if you want just the buckets or the middle section to. I used only the buckets but I like the seats because it has arm rest that fold up or down......but I did NOT have room to put the center piece in if I had wanted to. Just not enough room in my AD. Les, hope your having a good time in Denton. Chat later. | | |
