5 members (jmoore, fonz8261, gswbbc, Lugnutz, Dennys28), 78 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#952306 06/24/2013 1:17 PM
I finally got the ole girl running pretty good and need to find a muffler that has a decent sound. I was thinking maybe a straight-thru glass-pak or something. I don't want real quiet, but not to loud either...Where's a good place to get one?..TIA
'56 chevy...235 6 cylinder
most any FLAPS outa have one...
Give me ambiguity
or give me something else
Or Summit Racing Parts about $30 bucks for a Thrush Glasspack. I have set on my 86' GMC 1 ton (w/ bent motor) farmtruck and it's BADDDD and it'll booogie too. Cheap set of Summit headers on it also.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Ex Hall Monitor
Ex Hall Monitor
Your local farm store. I put a tractor muffler on my '38. It's a straight through glass pack.
I think the further back you put it (them) the sound will be better, the fella that put in my exhaust put them way forward and at about 2500 was horrid sounding. I put a set of maganaflo's all the way at the back and it is almost too quiet now. But at the same RPM it gives a nice tone now. But I still have the thrush in the middle, so I don't know how that affects things.
I looked at summits stuff, thanks for the advice, now I'm even more confused.
I was planning on just running a single glaspak out the back, would I be better if I ran 1 pipe in and 2 pipes out?..Looking for a mellow but not loud sound...
Your engine doesn't have enough compression for the deep throaty sounds of a V8, so don't compare V8 sounds and mufflers to a inline 6. Dual pipes will not make a performance difference, a little sound change is about all they do. Also pipe size matters, 2" would be maximum for a single exhaust system. Placing the muffler back at the axle will give a deeper tone and less ( rap rap ) then placing the muffler under the cab, it's long tail pipes give the inline six its distinctive sound.
Joe
Gas Pumper
Gas Pumper
Fun fact.. and I couldn't believe it, but the new Ford Mustangs have some sort of pipe-age that pipes the sound of the exhaust into the cabin so the driver can better appreciate the sound of the car. When cleaning things up and making things more efficient, its the first thing guys remove. Good grief! Im really getting too old for this s!!!!.
It reminds me of piping an efficient government into your head so you have this false conception that everything is sounding RIGHT ON MAN! lol.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
some of the new cars have a speaker making fake exhaust sounds.
I like a nice tone, but it is exactly the rap, rap that was anything but nice, abhorrent would be more like it. Just awful.
Looks like I've got more work to do since reading the wisdom of you guys. My original plan was to install the muffler right at the front of the bed , behind the cab, now it looks like I'll be getting another piece of pipe ( it's 2" dia) and moving the muffler on back towards the rear axle...
I can't really understand why it would make any difference, but you guys say so...it must be true...Thanks
