0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | This is what the rear fender washers look like on my 1951 Chevrolet suburban.There is ten per fender. rear fender washers Did I mention I'm needing just one washer,I have an add in the wanted section. Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Yup, they are also the same on my 52 panel. | | | | | Joined: Feb 2009 Posts: 4 New Guy | | New Guy Joined: Feb 2009 Posts: 4 | Tim, I got new bolts at the Carlisle show a couple years ago. They were exactly like the originals.I found that the washers would not come off the bolts. I may have a few left over ones if you want them. Let me know, I'll mail them to you. Jim
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | I have a 49 panel and the fenders were off when I got it (swiss cheese rust)and I don't have the hardware. Are the after market fender washers the same or just some flat style washer. If so any one know where I can obtain originals. It looks like they are made to hold good and not shift around. Thanks Craig
Still trying to get ole Betsy back on the road.
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | The original rears are 5/16" coarse thread bolts about an 1 1/4" in length with fairly large star like washers. These washers are affixed to the shank of the bolts and are slightly "mushroomed" so as to pinch the sheet metal tightly.
The washers are roughly an inch or so in diameter . All but two of mine were gone, too, so I just used new 5/16 bolts and flat washers .... worked fine. mike | | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Guess that's the way I'll go too then. Thanks
