4 members (walter74, Bisbee, Rusty Rod, UtahYork), 105 guests, and 3 robots.
Topics128,089
Posts1,056,437
Members48,443
#949101 06/09/2013 10:14 AM
I am using these taillights that have two wires
tailights
Do I still need to add a wire for the turnsignal? I am thinking the black wire is just a ground - but I am not electrical genius.
Still 6V?
If you are ordering the lights, order the ones already fitted for what you need. You will not have to add any wires, there would be no place to add them to anyway. One of those wires is for the brake light which is the same bulb (or filament) used with turn signals. The other is for the running (park) lights. Ground is accomplished with the mounting of the housing.
The blue dot may be illegal, check with the local police. The glass lenses do not emit as much visibility as the plastic.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
tail lights have 2 bulbs, or 2 filaments in a single bulb, one is for tail light [dimmer one], one for brake light [brighter one], so the 2 wires are for the 2 functions, the ground is via the bolts that mount the light to the bed .... if you want to add turn signals you need to 'insert' them into the brake light circuit or add separate lights
The turn signal switch determines whether you need separate lamps for the signals and brake lights.
