| | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | I am using these taillights that have two wires tailights Do I still need to add a wire for the turnsignal? I am thinking the black wire is just a ground - but I am not electrical genius. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Still 6V? If you are ordering the lights, order the ones already fitted for what you need. You will not have to add any wires, there would be no place to add them to anyway. One of those wires is for the brake light which is the same bulb (or filament) used with turn signals. The other is for the running (park) lights. Ground is accomplished with the mounting of the housing.
The blue dot may be illegal, check with the local police. The glass lenses do not emit as much visibility as the plastic.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | tail lights have 2 bulbs, or 2 filaments in a single bulb, one is for tail light [dimmer one], one for brake light [brighter one], so the 2 wires are for the 2 functions, the ground is via the bolts that mount the light to the bed .... if you want to add turn signals you need to 'insert' them into the brake light circuit or add separate lights
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The turn signal switch determines whether you need separate lamps for the signals and brake lights. | | |
