1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94707 02/17/2006 12:17 AM | Joined: Feb 2006 Posts: 29 Apprentice | | Apprentice Joined: Feb 2006 Posts: 29 | dose any body know what colour the high beam warning light should be on a 51? i assume its a lense over tha dash light bulb.cheers | | |
#94708 02/17/2006 7:38 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I'm pretty sure that it is supposed to be red. There's a lightbulb (1 or 2 candlepower) that goes into the dash (I think) that lights up a translucent red dot, which indicates the high beams.
The only 51 that I have access to is currently indisposed in the woods under 3 feet of snow, so I can't verify that, but I'm pretty sure that it was red. | | |
#94709 02/17/2006 7:52 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I'll second that Jon. Red it is. Cecil......... | | |
#94710 02/19/2006 6:37 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | just be happy your light works, its low wattage and a small hole to shine through. green is better on the eyes and that red should be for your gen/alt indicator lamp
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#94711 02/19/2006 2:26 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | But it is red. Jim, you have a generator indicator light in your 51? | | |
#94712 02/19/2006 9:10 PM | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 |
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
#94713 02/20/2006 8:04 PM | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | and on my 61 it is red!! Hobert
"The Lord is my shepherd"
#94714 02/20/2006 9:47 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | | | |
#94715 02/20/2006 9:54 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I knew it.
It's red on my '46, too. | | |
#94716 02/21/2006 3:50 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | my 51 does not have any colored lens that shows color at that location ~ 6pm on the gauge. if i stick in a bulb it shows white. I have now changed to modern gauges and they do not have any provisions for high /low, gen/ alt failures. so i purchased an ''led'' from my local electrical shop and will solder in a resistor, drill a 1/4'' hole in the dash for this purpose.
#94717 02/27/2006 3:52 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Yes, the upper beam indicator is red. There is a little spec of colored translucent material in the housing, or there should be. | | |
