4 members (Otto Skorzeny, moparguy, delky, 1 invisible), 104 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#94707 02/17/2006 12:17 AM
Apprentice
Apprentice
dose any body know what colour the high beam warning light should be on a 51? i assume its a lense over tha dash light bulb.cheers
#94708 02/17/2006 7:38 AM
I'm pretty sure that it is supposed to be red. There's a lightbulb (1 or 2 candlepower) that goes into the dash (I think) that lights up a translucent red dot, which indicates the high beams.
The only 51 that I have access to is currently indisposed in the woods under 3 feet of snow, so I can't verify that, but I'm pretty sure that it was red.
#94709 02/17/2006 7:52 AM
I'll second that Jon. Red it is. Cecil.........
#94710 02/19/2006 6:37 AM
just be happy your light works, its low wattage and a small hole to shine through.
green is better on the eyes and that red should be for your gen/alt indicator lamp
Jim & Caroline
#94711 02/19/2006 2:26 PM
But it is red.
Jim, you have a generator indicator light in your 51?
#94712 02/19/2006 9:10 PM
on my 61 it is red.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#94713 02/20/2006 8:04 PM
and on my 61 it is red!!
Hobert
"The Lord is my shepherd"
#94714 02/20/2006 9:47 PM
2 Offline
On a 51 it is red.
#94715 02/20/2006 9:54 PM
I knew it.
It's red on my '46, too.
#94716 02/21/2006 3:50 PM
my 51 does not have any colored lens that shows color at that location ~ 6pm on the gauge. if i stick in a bulb it shows white. I have now changed to modern gauges and they do not have any provisions for high /low, gen/ alt failures. so i purchased an ''led'' from my local electrical shop and will solder in a resistor, drill a 1/4'' hole in the dash for this purpose.
Jim & Caroline
#94717 02/27/2006 3:52 AM
Yes, the upper beam indicator is red. There is a little spec of colored translucent material in the housing, or there should be.
1951 1 Ton Completed
