1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#94481 02/02/2006 2:03 AM
I replaced my gas tank and unit in my 55 Chevy PU and still the gauge does not work. While reading in a Classic Performance Products Catalog, it said that the newer sender unit had a 90 ohm resistor and that the old sender was a 30 ohm resistor. Since I used the tank and sender unit from an 88 S-10 Blazer (fits well in the frame where the spare tire goes), I assumed the sender unit is a 90 ohm because my gauge will not work. frown
So here is the question. Where could I find a resistor to change the 90 ohm to 30 ohms to use my stock gauge, or do I buy the “30 ohm” sender unit from CPP and hope it works in the new tank?
cool
the sending unit and gauge for sure have to match,,dont know much about resistor change, I had a problem doing mine in my 52 so I cheated and bought after market gauge and sending unit to match,, they for sure do have to match,, sorry I wasn't much help.. I know that I am glad that I do have one that works even though it is under my dash,,Fred
Redryder pix
My Hotrod
sport55,
Methinks no resistor...buy sender and make it work!
Stuart
#94484 02/02/2006 11:14 PM
I had the same problem awhile back on my Nova. The easiest is to buy a new sending unit. But, what happened to me is the sending unit still didn't fix the problem. I ended up sending both units to a gauge shop and had them recalibrated to make it work. Cost was under $50., so not to bad. Cecil...........
Did you make sure you have a good ground from the sender to the cab? That was one of the first things I had to fix on my 62 when I got it.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
