| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94481 02/02/2006 2:03 AM | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | I replaced my gas tank and unit in my 55 Chevy PU and still the gauge does not work. While reading in a Classic Performance Products Catalog, it said that the newer sender unit had a 90 ohm resistor and that the old sender was a 30 ohm resistor. Since I used the tank and sender unit from an 88 S-10 Blazer (fits well in the frame where the spare tire goes), I assumed the sender unit is a 90 ohm because my gauge will not work. So here is the question. Where could I find a resistor to change the 90 ohm to 30 ohms to use my stock gauge, or do I buy the “30 ohm” sender unit from CPP and hope it works in the new tank? Thanks  | | |
#94482 02/02/2006 2:33 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | the sending unit and gauge for sure have to match,,dont know much about resistor change, I had a problem doing mine in my 52 so I cheated and bought after market gauge and sending unit to match,, they for sure do have to match,, sorry I wasn't much help.. I know that I am glad that I do have one that works even though it is under my dash,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#94483 02/02/2006 2:34 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | sport55,
Methinks no resistor...buy sender and make it work!
Stuart | | |
#94484 02/02/2006 11:14 PM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I had the same problem awhile back on my Nova. The easiest is to buy a new sending unit. But, what happened to me is the sending unit still didn't fix the problem. I ended up sending both units to a gauge shop and had them recalibrated to make it work. Cost was under $50., so not to bad. Cecil........... | | |
#94485 02/05/2006 6:52 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Did you make sure you have a good ground from the sender to the cab? That was one of the first things I had to fix on my 62 when I got it. Speed | | |
