BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: May 2005 Posts: 1,624 Shop Shark | Shop Shark Joined: May 2005 Posts: 1,624 | The brakes on my street rod continue to give me grief. I need to find the best way to bleed them once and for all. The facts: Under floor m/c with two stage (pancake) 7" booster. Thru floor pedal Corvette dual m/c (two large reservoirs), 1-1/8 bore Corvette 11" disc front, '86 Camaro rear drums 2 pound residual valve front, 10 pound rear.
I lost the front brakes at the NSRA south show over last weekend from a failed rubber front left hose. Replaced the hose and attempting to bleed the front. I would like to be sure no air is left in the lines. This is always a problem as the rubber lines and maybe other parts are above the m/c. I have a hand vacuum pump, an electric vacuum pump, self bleeders and normal bleed valves. How would you do it? Thanks
| | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If you have air in them you should be able to "pump up the pedal" and then let it sit for a few minutes. The press the brake pedal down and see if it goes down lower than where you pumped it up to. If that happens you surely have air in them.
Since you only messed with the front I'd think those are the only ones needing to be bled.....and in most cases I'd say only the one wheel where you replaced the line. Maybe someone who has had the same problem will chip in here. | | | | Joined: Feb 2011 Posts: 1,329 'Bolter | 'Bolter Joined: Feb 2011 Posts: 1,329 | First always make sure the master cyl is full while bleeding. Start with the farthest away from the MC wheel cyl and if using a vaccum you need the special little jar deal so you don't suck brake fluid into the vac pump. Hook up that bleed setup and loosen the bleed valve at the wheel cyl, till the little jar fills about 3/4 full, then close the bleed valve and empty the jar. Do that about 2 to 3 times, then move on to the next farthest wheel cyl, repeat. The closest one is last. That should do it. The thing you want is no bubbles comming into the little bleeder jar.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | Joined: Feb 2006 Posts: 549 Shop Shark | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | Shop Shark Joined: May 2005 Posts: 1,624 | I guess I need to distill my question some. When one goes into their FAPS and gets a master cylinder there no instructions as to which reservoir is for front and rear (at least not that I have seen). I looked at the very good "MPB" web site for some insight. They show a number of master cylinder hook ups. You guess it, some pics show the front brakes going to the reservoir closest to the booster. Other pics show the reverse. When I bench bleed this m/c I closely watched which reservoir moved brake fluid first. Another question is, which system is suppose to start braking first, front or rear? Please remember, this is a street rod. You don't usually go into the auto parts store and ask for the parts by make and model then drop it in. Thanks
| | | | Joined: Feb 2006 Posts: 549 Shop Shark | Shop Shark Joined: Feb 2006 Posts: 549 | You could trace your lines to find which is front and which is back on your "street rod" if you only want to bleed one side.
If it were me, and the brakes were working well before things went south, I'd assume they were routed correctly and bleed all of them. | | | | Joined: Mar 2005 Posts: 576 Shop Shark | Shop Shark Joined: Mar 2005 Posts: 576 | x2 on bleeding them all.....we used a vacuum bleeder to do mine...it was a new install on the whole system...lots of leaks..but eventually got it done......whid 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | Joined: May 2005 Posts: 1,624 Shop Shark | Shop Shark Joined: May 2005 Posts: 1,624 | Hopefully hopeing to not sound like a smart a** but please retread my questions. I am very familiar with my brake lines as I put them in. Thanks
| | | | Joined: Feb 2006 Posts: 549 Shop Shark | Shop Shark Joined: Feb 2006 Posts: 549 | Replaced the hose and attempting to bleed the front. I would bleed the entire circuit I would like to be sure no air is left in the lines. This is always a problem as the rubber lines and maybe other parts are above the m/c. If you can’t access the MC, I would clean that up. You have to fill it eventually. I have a hand vacuum pump, an electric vacuum pump, self bleeders and normal bleed valves. How would you do it? Motive pressure bleeder. But that’s just me…
| | | | Joined: May 2006 Posts: 8,351 'Bolter | 'Bolter Joined: May 2006 Posts: 8,351 | I would bleed the entire circuit
Motive pressure bleeder. Agreed on both counts. It was also mentioned to bleed starting with the cylinder furthest away from the MC. What you would want to do is start with the longest line, which, depending on how the lines are routed, could be either the RR or LR. I would suggest checking the routing of the lines to determine which one is the longest line.
Bill Burmeister | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | 'Bolter Joined: Apr 2005 Posts: 1,107 | i have a problem bleeding brake by myself. my 40 is a pain. i got a set of these. http://www.speedbleeder.com/i got mine for napa. i did the complete truck including the hydravac in less then a half hour. theyre sort of pricey but its less than the cost of frustration. | | | | Joined: Aug 2012 Posts: 566 Shop Shark | Shop Shark Joined: Aug 2012 Posts: 566 | This is what I saw at homemadetools.net website http://www.homemadetools.net/power-bleeder-2?utm_expid=57824293-7&utm_referrer=http%3A%2F%2Fwww.homemadetools.net%2Ftag%2Fbrake-bleeding http://forums.corvetteforum.com/c3-...wer-bleeder-for-14-a.html#post1578587678
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | Joined: May 2005 Posts: 1,624 Shop Shark | Shop Shark Joined: May 2005 Posts: 1,624 | Update.... Tried using both the hand vacuum pump and the electric vacuum pump with speed bleeders. I could not get a good seal where the vacuum hose fits over the bleeder nipple. It kept leaking air and was impossible to tell if air bubbles were from the the brake line or air leak. I was using clear Tygon tubing. Had more luck with the self bleeders and pumping the brake pedal. I like TimyJaime power bleeder. The problem I would have with it are the clamps. It's very cramped around my m/c with tubing, residual valves, and frame members.
| | | | Joined: Aug 2012 Posts: 566 Shop Shark | Shop Shark Joined: Aug 2012 Posts: 566 | Yes i agree about the space issue. Mine too is under the cab however my cab is off so mine is wide open right now but i am planning to install a mini door or access panel for future service. I did not think of other peoples situations. Well good luck with it.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | Joined: May 2005 Posts: 1,624 Shop Shark | Shop Shark Joined: May 2005 Posts: 1,624 | It's done. What worked best for me.... using the brake pedal with the self bleeders. As stated above, in using the vacuum pumps I couldn't tell where the air bubbles were coming from. If someone has a good way to get a rubber hose on the bleeder nipple I would be interested in reading about it. Thanks
| | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | Shop Shark Joined: Nov 2006 Posts: 2,544 | Don't buy the cheap vinyl tubing, get the softer stuff, I know its used for fish tank air pumps and I have had good luck with it staying on the bleeders. | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... I just tried what I had laying in the shop. Be it vacuum hose or windshield washer hose ect...
I used the speed bleeders myself and love them. | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | 'Bolter Joined: Apr 2005 Posts: 1,107 | Update.... Tried using both the hand vacuum pump and the electric vacuum pump with speed bleeders. I could not get a good seal where the vacuum hose fits over the bleeder nipple. It kept leaking air and was impossible to tell if air bubbles were from the the brake line or air leak. I was using clear Tygon tubing. Had more luck with the self bleeders and pumping the brake pedal. the speed bleeder eliminates the use of any other bleeding type device. its the brake pedal and master cylinder that does all the work. as for a hose over the end of a bleeder to catch fluid and not leak air the tighter the better method is best. with a speed bleeder you'll get no air bubbles from the bleeder when your not pressing the brake pedal. you'll get no air bubbles going back into the bleeder unless of coarse the check valve in the bleeder is faulty or was rendered useless due to junk in the fluid from old dirty nasty brake lines that havent been replaced . The problem I would have with it are the clamps. It's very cramped around my m/c with tubing, residual valves, and frame members ahh the price of modifications  | | |
