6 members (sron48, Charles in CA, Gray_Ghost, 66flea, Wally / Montana, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,757
#942807 05/12/2013 10:44 PM
I
I Offline
Any recommendations on a controller for an electric fan?
I'm putting a 1956 235 in my 1940 1 1/2 ton. The fan hits the lower radiator outflow. The head is a 3835913 which has the smaller temperate sensor.
I've never run an electric fan and so I'm not sure which sensor will work or where to hook it up.
Any advice is appreciated.
I just run mine off a toggle switch.
Bill Burmeister
Mine is a V8 but I think you can certainly use them on a 6 cylinder. I ordered my sensor from Speedway. Good folks, good prices. I have mine wired to where it comes on/off automatically but I also have a toggle switch which I can cut the fan on automatically should the sensor go bad. Call it overkill but with sensors you just never know these days! Give Speedway a call and tell them what you want to do.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
