11 members (Joe H, Jay R, jmoore, GMCJammer51, 55shaker, Bucker, sron48, Shade Baby, Gray_Ghost, GIJOE298, Otto Skorzeny),
137
0
Mod | | | Forums66 Topics128,157 Posts1,056,894 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 2,990 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,990 | | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Nice work! Now to get all back together! | | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | Jay, where did you find your cab lights? I have them on my '36 and I've not seen another set? | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Looks better than when it was off the assembly line. | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Nice, nice, nice.....The color looks great! | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I would be proud to have that truck. Nice job, keep the pics coming. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Looking great! Beautiful paint job! I am looking forward to getting some paint on mine. But its gonna be a while, lots of work first. I assume since thats a 2010 color, its base coat-clear coat? My son has a body shop and only works on late model cars. He uses this system, but I am not familar with it. I was spraying Acrilic Enamel when doing the old muscle cars and then when I started doing farm tractors, went to using Synthetic Enamel. I may just get the son to spray mine, he is hooked up with Dupont and they installed his own mixing system for him.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | assembly almost complete https://plus.google.com/u/1/photos/.../5872849867326518833/5876573596077827778if you look closely, the fenders are hanging up in the background (black ones). only thing left to do is put in the back window, fix a brake hose leak ( I suck as making flares), putting in the door glass, and hooking up the dash electrical. I pulled off the front hubs, no grease in the bearings, and 3 black widow spiders living in them. boy those brake shoes are small for such a large truck! | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | i got the cab lights on ebay, the are arrow lights. in california, prior to 1969 you can have green lights in the center. So I put them in. the front yellow lights are from rodtiques. 2 filament lights, both driving and turn signals.
after I get her going, I need to look at the rear end. seems to be a little play and its weeping fluid. im a gonna need to call in the cavalry for that one | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | the paint is ppg base/clear, its 2010 mazda pearl red and pearl black. lucky's speed shop in freemont ca did the metal work, english wheel on the fenders, and lots of spooning on the cab. very very little bondo, lots of block sanding with filler primer. so it was: baked all parts, then blasted off the ash etching primer filler primer epoxy sealing primer base coat clear coat.
since I painted it in my barn, I have my share of nats and other small bugs in the paint. but hey, its a truck. | | |
