8 members (Hotrod Lincoln, sudsyz, Chip O, Gdads51, 1955 1 Series, stlcardinalsguy, tclederman, 1 invisible), 67 guests, and 0 robots.
Topics128,210
Posts1,057,456
Members48,471
b10
Offline
I was reading on one of your post about early Buick vehicles using felt inside on the top of the valve cover to cut the sound i now have after installing my son-inlaws gift.It looks great but the old cover makes the engine quiet cause it is much thicker Steel. What kind of FELT is this? -Thanks Anyone
Glue some cork to the under side. Felt would work, but make sure it's secure, you wouldn't want it to rub the rockers or you will get fuzzy's all thru the motor.
Joe
Hi Joe,
What is the best thing to use to glue cork on to the underside of the valve cover. I have a chrome cover for my 235, that I haven't put on yet.
Thanks John
b10
Offline
Will HOT glue gun Or Epoxy work on cork? How about Roll Rubber Stoker gasket,I have a mess of it and it is thicker. THANKS for info.
Ex Hall Monitor
Ex Hall Monitor
I wouldn't trust it personally. A glue that softens in heat on an engine that gets hot doesn't sound good to me.
My Blog
b10
Offline
One thing is for sure I always get more ideas to choose from than can be used and all you people are so fast with info. As always THANKS!!!
It talks about it in this book Cailfornia Bob's Cheverolet, GMC & Buick Speed Manual, the 1954 edition
Here is what I asked in this forum a little while back. https://www.stovebolt.com/ubbthread...lat&Main=131130&Number=887569#Post887569
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
I would think plain old silicone would hold cork. It holds gaskets pretty well. Really clean and rough up the surface then clean again with alcohol. You should have any problem with it sticking.
Joe
3M weatherstrip adhesive.
Joe
1955 First Series 3100
Geeze I'd forgotten about those pads, the shop that rebuilt my 30 Chevy motor many years back had those in stock. Joe said, "hey son here's what you'll need for your motor, the Chevrolet KOTEX", as he called them. The pad was soaked in oil for a week then fit over the studs holding valve cover down, seamed to help with noise a bit.
Since the first automobile rolled out of the factory, companies were constantly hawking some kind of gadget.
1946 1/2-Ton Chevy
the really best way would be to get an aluminum cover, if it is really bothering you that much. There is not even a slight chance I would purposely put a foreign object inside my engine. I made an extreme effort to purposely keep them OUT.
