| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Wheels are on! http://rustyfiftyone.com/dont-step-on-my-teal-suede-shoes/They look a bit blue in the pics. The color is called Sterling Teal and it's almost an exact match to Tiffany blue which is more of a teal color. ...hence the name Sterling Teal since, for those who don't know, Tiffany & Co is known for it's silver. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Nice shuz  Today I put the 50 on jack stands and greased the king pins and spring shackles. Found a cotter pin had fallen from the castle nut on the the steering link. Drag link was loose also. Hit those zerts, tightened everything up and reinstalled new cotter pins. Glad I found that. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My alternator took a dump yesterday,one downside of living in the UK,I can't just pop down to the local FLAPS and get a new one,or bearings,heck the guy couldn't even cross refer a fan belt number so what chance have I got? One step forward,two steps back as they say...... John, Some possible solutions for you: On the fan belt issue you might look for a belt the same length and width as your original. A bit more complicated for the alt.. I would try to identify an alt. that produces the same voltage and build a bracket for it. You might need to take a course in auto electrical but once done you will have a source for the next belt and alt you will certainly need.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | John, Some possible solutions for you: On the fan belt issue you might look for a belt the same length and width as your original. A bit more complicated for the alt.. I would try to identify an alt. that produces the same voltage and build a bracket for it. You might need to take a course in auto electrical but once done you will have a source for the next belt and alt you will certainly need. Thanks Jim,got it fixed today. The problem wasn't so much I couldn't get the parts at all, it was more the fact it was Sunday and the proper FLAPS are shut. Gearheads are not as well catered for here. I had the alternator checked out today and everything's fine,even if it wasn't I would have had it rebuilt. Turns out the belt i'd fitted was too narrow and jammed in the pulley groove. Switched to a wider belt of the same length and couldn't get it to fit,it pulled the alternator so close to the rocker cover it was touching. I forgot to allow that the belt would ride higher in the groove which involved second trip to the FLAPS for a longer belt....  Bottom line,it's fixed and doesn't scream like a banshee every time I rev it now....
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Dave,we've met on Flickr (solo1950) I didn't realise you already hung out here,so no point in me "preaching to the converted". BTW got the POR-15 off your arms yet?  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Dave, looks great! I need to invest in some of that POR15 stuff once I get to the body work. Dave,we've met on Flickr (solo1950) I didn't realise you already hung out here,so no point in me "preaching to the converted". We've got a pretty regular group going on flickr now.  | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Put the 'Burb up on jacks. Removed the driveshaft. Removed the tailhousing. Removed the improper speedo drive gear. Installed the new drive gear. Installed the tailhousing. Installed the speedo driven gear. Reinstalled the driveshaft. Installed the VSS. Gonna be tight for the speedo cable. Tranny service is next. Then more harness install. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Put the 'Burb up on jacks. Removed the driveshaft. Removed the tailhousing. Removed the improper speedo drive gear. Installed the new drive gear. Installed the tailhousing. Installed the speedo driven gear. Reinstalled the driveshaft. Installed the VSS. Gonna be tight for the speedo cable. Tranny service is next. Then more harness install. Dang! You've been busy.
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Adjusted the valves on the burb tonight. Every one was too tight. I hope that clears the top end trouble she's been having. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | I try to work on it for at least a couple hours a day. I'm getting close!!  | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Serviced the tranny. New filter, fresh fluid. Started installing the drivers side exhaust, muffler. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Got the alternator refitted (I couldn't resist giving it a polish)with the new wider belt,traced a battery drain problem to the ignition switch,re-adjusted it and all seems well. The acid test will be this morning. Attended to some smaller issues like a rattling interior light while I was waiting for the battery to charge.
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Had to do a little welding on the muffler / pipe. The band clamp wasn't cutting it. Hopefully, tonight, I can install the new knock sensor, install the O2 sensor, get serious about running the harness under the seat, make a mount for the computer. A lot to do. Like Dory says, just keep swimmin'! | | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | My 76 yr old dad is a former mechanic by trade. he and my mom came into town visit for weekend. We just came back spending quality time at a junk yard, picking a spare tire winch for my '51 for $25.
1951 Chevy 3100 | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Installed new wheels, trim rings an hub caps. I had these new smoothie wheels powder coated a lite cream color and new radials are 215/75/R15 narrow WW
Love the look. No pics up yet | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 |
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Robert, You did an excellent job. I have to say it looks great. Can you take some pics of it outside? I assume you will be installing the bed wood? (we have the same year and model truck).... | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | That's looking great Robert,like David i'd like to see it out in that sweet Virginia sunshine......c'mon now don't be shy! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Got to the bottom of my battery drain problem,an open circuit in the ignition switch,thought it was just a simple adjustment but there's more to it than I first thought,so a new switch is required. On a brighter note the engine's running cooler now thanks to the correct fan belt. (no slippage) 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Adjusted the opening around the E brake pedal. Installed the parking brake rod. Installed the O2 sensor. Loaded it up on the trailer, brought it home. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Robert, You did an excellent job. I have to say it looks great. Can you take some pics of it outside? I assume you will be installing the bed wood? (we have the same year and model truck).... The bed wood is next. I'll get some pics outside this weekend.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....got the "brackets" welded for mounting the top part of my rear shocks. Sure does ride/handle better but I still think a sway bar is in order!! I now have about 85 miles on the panel and its purrrrring along just fine. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Re-adjusted the front suspension again,thanks to some spurious info gleaned from the internet......  Finally got it to a state safe enough to drive to the alignment shop today. Still grinning from the drive home.......
| | | | | Joined: Apr 2013 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 62 | last night after i put "heads in beds", i went out with my headlamp on redlight, put on the new drivebelt (napa gave me the wrong size, went back and guesstimated a currect size), tensioned it, installed the new water pump, thermostat housing with a new thermostat, hooked up all the coolant lines, and bolted down the hood latch assembly.
wouldn't have looked like such a weirdo if i had a closed garage instead of a parking lot with a headlamp, but i don't care. i'm determined to get this thing on the road before summer ends. now that i have a stovebolt, i see them all over the road and i get jealous. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | That's looking great Robert,like David i'd like to see it out in that sweet Virginia sunshine......c'mon now don't be shy! Here you go! Onetwothreefour
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | Finished making new interior kick panels for the 1953. They match the door panels. Will install them tomorrow.  | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Did nothing but haul trash to the dump site.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Pulled the temporary fuel line (rubber) off between tank and pump and started bending up some stainless tubing. I've only messed up twice - glad I bought extra tubing! | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Removed and sandblasted stake pockets from LH side of bed on my 49' 3600. Also cut the top section off a half inch below the bend and welded entire new sheet metal side. Now working on fudging in a repro stake pocket on the rear end of it....
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | Got one of the headlight buckets pulled, sanded, painted, and gaskets put (mostly) on. Also got the rear end from the 66 half ton measured. Looks like we have a winner! Will need to move the perches a bit and get some shock mounts made up, but at least I know we're in the ballpark now! | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Got the welding started on the bottom of one of the doors (the other door is fine). Ran out of welding wire  Also got the bed frame POR-15'd with a UV safe product they have called "Top-Coat". It's satin and went on pretty nice. Still have to turn it over and do the other side. Also got some Fat-Mat put in the back of the cab for sound deadening and insulation. http://www.flickr.com/photos/ajporsche/8708325575/Busy weekend..... | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Installed two-element sockets in the new tail lights (in preparation for a re-wire and addition of turn signals) and marked the new front cross-sill for mounting holes.
Getting ready to repair steering wheel cracks and re-paint it.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Got my door panels and a small bag of black powder coat for the stainless frames. Hope to get em done this week. ...hope they fit in the oven.  | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Changed the oil and replaced the filter in my InnerLine. ...got a couple miles from my house and the pressure hit ZERO. Stupid gasket on the top of the InnerLine canister didn't seat correctly. Lost three and a half quarts and I left a trail from my house to the gas station where I pulled in.
Now I have to decide if I want to dump the generic 10w-40 I added to get home and refill with the good stuff (20-50 w/zddp) or just leave it for now. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Changed the oil and replaced the filter in my InnerLine. ...got a couple miles from my house and the pressure hit ZERO. Stupid gasket on the top of the InnerLine canister didn't seat correctly. Lost three and a half quarts and I left a trail from my house to the gas station where I pulled in.
Now I have to decide if I want to dump the generic 10w-40 I added to get home and refill with the good stuff (20-50 w/zddp) or just leave it for now. I vote the "peace of mind" approach. Put the good stuff back in.
~Jim
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Put ATF in my manual T-5 hope it works out as everyone says. | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I got a email ,my door bottom has been shipped,so I will be able to finish my door this weekend.Hope that counts as progress | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Well, after over a 100 miles on the panel I got tired of "waiting on it to change one more time" so I took my 700R4 to a tranny man I know to rebuild it. Next week I'll be taking the 350 out and putting in the 700R4. It was the dangest thing. Riding along and just waiting/wanting it to change "one more time". I like the 700 in my 37 so good I think it spoiled me. | | |
