2 members (Gdads51, GrandpasJimmy), 134 guests, and 0 robots.
Topics128,191
Posts1,057,364
Members48,469
Page 92 of 177 1 2 … 90 91 92 93 94 … 176 177
Wheels are on! cool
http://rustyfiftyone.com/dont-step-on-my-teal-suede-shoes/
They look a bit blue in the pics. The color is called Sterling Teal and it's almost an exact match to Tiffany blue which is more of a teal color. ...hence the name Sterling Teal since, for those who don't know, Tiffany & Co is known for it's silver.
Originally Posted by BLUEMEANIE
Nice shuz thumbs_up
Today I put the 50 on jack stands and greased the king pins and spring shackles.
Found a cotter pin had fallen from the castle nut on the the steering link.
Drag link was loose also. Hit those zerts, tightened everything up and reinstalled new cotter pins.
Glad I found that.
My alternator took a dump yesterday,one downside of living in the UK,I can't just pop down to the local FLAPS and get a new one,or bearings,heck the guy couldn't even cross refer a fan belt number so what chance have I got?
One step forward,two steps back as they say......
John,
Some possible solutions for you:
On the fan belt issue you might look for a belt the same length and width as your original. A bit more complicated for the alt.. I would try to identify an alt. that produces the same voltage and build a bracket for it. You might need to take a course in auto electrical but once done you will have a source for the next belt and alt you will certainly need.
~Jim
John,
Thanks Jim,got it fixed today.
The problem wasn't so much I couldn't get the parts at all, it was more the fact it was Sunday and the proper FLAPS are shut.
Gearheads are not as well catered for here.
I had the alternator checked out today and everything's fine,even if it wasn't I would have had it rebuilt.
Turns out the belt i'd fitted was too narrow and jammed in the pulley groove.
Switched to a wider belt of the same length and couldn't get it to fit,it pulled the alternator so close to the rocker cover it was touching.
I forgot to allow that the belt would ride higher in the groove which involved second trip to the FLAPS for a longer belt.... dang
Bottom line,it's fixed and doesn't scream like a banshee every time I rev it now....
More pix on Flickr.
Originally Posted by OldDawg
I got the panels behind the fuel tank, the floors and the footwells all POR-15'd up.
http://www.flickr.com/photos/ajporsche/8690605467/
I've got some metal work to do on the bottom of the doors next....
Dave,we've met on Flickr (solo1950)
I didn't realise you already hung out here,so no point in me "preaching to the converted".
BTW got the POR-15 off your arms yet? wink
More pix on Flickr.
Dave, looks great! I need to invest in some of that POR15 stuff once I get to the body work.
We've got a pretty regular group going on flickr now. smile
Put the 'Burb up on jacks. Removed the driveshaft. Removed the tailhousing. Removed the improper speedo drive gear. Installed the new drive gear. Installed the tailhousing. Installed the speedo driven gear. Reinstalled the driveshaft. Installed the VSS. Gonna be tight for the speedo cable. Tranny service is next. Then more harness install.
Dang! You've been busy.
~Jim
Adjusted the valves on the burb tonight. Every one was too tight. I hope that clears the top end trouble she's been having.
I try to work on it for at least a couple hours a day. I'm getting close!! thumbs_up
I have the cab just about finished, all I need is to install the emblems that just arrive back from the chrome platers
http://s783.photobucket.com/user/jo...amp;_suid=136733118340709578044729093115
It was a bear to get the hood to sit flat, finally had to machine the screw holes to give it more travel down
Build So far:
http://s783.photobucket.com/user/johntsmith1056/slideshow/59%20chevy%20pick%20up%20project?sort=6
I'm working on the bed now, but the doc says he has to go cut on me to attach some tendons I tore off. So it'll sit now for most of the summer. Tough getting old....
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Serviced the tranny. New filter, fresh fluid. Started installing the drivers side exhaust, muffler.
Got the alternator refitted (I couldn't resist giving it a polish)with the new wider belt,traced a battery drain problem to the ignition switch,re-adjusted it and all seems well.
The acid test will be this morning.
Attended to some smaller issues like a rattling interior light while I was waiting for the battery to charge.
More pix on Flickr.
Had to do a little welding on the muffler / pipe. The band clamp wasn't cutting it. Hopefully, tonight, I can install the new knock sensor, install the O2 sensor, get serious about running the harness under the seat, make a mount for the computer. A lot to do. Like Dory says, just keep swimmin'!
My 76 yr old dad is a former mechanic by trade. he and my mom came into town visit for weekend. We just came back spending quality time at a junk yard, picking a spare tire winch for my '51 for $25.
1951 Chevy 3100
Installed new wheels, trim rings an hub caps. I had these new smoothie wheels powder coated a lite cream color and new radials are 215/75/R15 narrow WW
Love the look. No pics up yet
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Robert C.
I'm a Genius in the making.
1950 3600
Robert,
You did an excellent job. I have to say it looks great. Can you take some pics of it outside? I assume you will be installing the bed wood? (we have the same year and model truck)....
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Originally Posted by mobileortho
That's looking great Robert,like David i'd like to see it out in that sweet Virginia sunshine......c'mon now don't be shy!
More pix on Flickr.
Got to the bottom of my battery drain problem,an open circuit in the ignition switch,thought it was just a simple adjustment but there's more to it than I first thought,so a new switch is required.
On a brighter note the engine's running cooler now thanks to the correct fan belt. (no slippage)
More pix on Flickr.
Adjusted the opening around the E brake pedal. Installed the parking brake rod. Installed the O2 sensor. Loaded it up on the trailer, brought it home.
Originally Posted by DMGfifty
Robert,
The bed wood is next. I'll get some pics outside this weekend.
Robert C.
1950 3600
....got the "brackets" welded for mounting the top part of my rear shocks. Sure does ride/handle better but I still think a sway bar is in order!! I now have about 85 miles on the panel and its purrrrring along just fine.
Re-adjusted the front suspension again,thanks to some spurious info gleaned from the internet...... computerdeath
Finally got it to a state safe enough to drive to the alignment shop today.
Still grinning from the drive home....... grin
More pix on Flickr.
Did a road trip in the ole orange crate today now that its pretty much road worthy. First time its been out on the open road for about 5 years. Time flies when your having fun.
We took our GPS to confirm the speedometer is accurate, which it was to my surprise. I would have figured the huge rear tires would have thrown it off a bit. All in all a good first outing.
Gearing and tires produce 2000 RPM at 50 MPH in 4th gear. Which is pretty much what I had figured.
http://i645.photobucket.com/albums/...Status%20Photos/DSCF2110_zpsf6b47dcb.jpg
http://i645.photobucket.com/albums/...Status%20Photos/DSCF2112_zps722db841.jpg
http://i645.photobucket.com/albums/...0Photos/2621897210103882008mTylTc_fs.jpg
last night after i put "heads in beds", i went out with my headlamp on redlight, put on the new drivebelt (napa gave me the wrong size, went back and guesstimated a currect size), tensioned it, installed the new water pump, thermostat housing with a new thermostat, hooked up all the coolant lines, and bolted down the hood latch assembly.
wouldn't have looked like such a weirdo if i had a closed garage instead of a parking lot with a headlamp, but i don't care. i'm determined to get this thing on the road before summer ends. now that i have a stovebolt, i see them all over the road and i get jealous.
Here you go!
One
two
three
four
Robert C.
1950 3600
Finished making new interior kick panels for the 1953. They match the door panels. Will install them tomorrow. chug
"IT IS WHAT IT IS"
1953 Chevrolet 1/2-ton 3100 4x4
In the DITY Gallery
More images in Flickr
1948 GMC 1-Ton (now sold to someone in Hawaii!)
More photo in Flickr
1953 Chevy 1-Ton
Did nothing but haul trash to the dump site.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Pulled the temporary fuel line (rubber) off between tank and pump and started bending up some stainless tubing. I've only messed up twice - glad I bought extra tubing!
Removed and sandblasted stake pockets from LH side of bed on my 49' 3600. Also cut the top section off a half inch below the bend and welded entire new sheet metal side. Now working on fudging in a repro stake pocket on the rear end of it....
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Got one of the headlight buckets pulled, sanded, painted, and gaskets put (mostly) on. Also got the rear end from the 66 half ton measured. Looks like we have a winner! Will need to move the perches a bit and get some shock mounts made up, but at least I know we're in the ballpark now!
Got the welding started on the bottom of one of the doors (the other door is fine). Ran out of welding wire frown
Also got the bed frame POR-15'd with a UV safe product they have called "Top-Coat". It's satin and went on pretty nice. Still have to turn it over and do the other side.
Also got some Fat-Mat put in the back of the cab for sound deadening and insulation.
http://www.flickr.com/photos/ajporsche/8708325575/
Busy weekend.....
Installed two-element sockets in the new tail lights (in preparation for a re-wire and addition of turn signals) and marked the new front cross-sill for mounting holes.
Getting ready to repair steering wheel cracks and re-paint it.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Got my door panels and a small bag of black powder coat for the stainless frames. Hope to get em done this week. ...hope they fit in the oven. blush
Changed the oil and replaced the filter in my InnerLine. ...got a couple miles from my house and the pressure hit ZERO. Stupid gasket on the top of the InnerLine canister didn't seat correctly. Lost three and a half quarts and I left a trail from my house to the gas station where I pulled in.
Now I have to decide if I want to dump the generic 10w-40 I added to get home and refill with the good stuff (20-50 w/zddp) or just leave it for now.
I vote the "peace of mind" approach. Put the good stuff back in.
~Jim
Put ATF in my manual T-5 hope it works out as everyone says.
I got a email ,my door bottom has been shipped,so I will be able to finish my door this weekend.Hope that counts as progress
Well, after over a 100 miles on the panel I got tired of "waiting on it to change one more time" so I took my 700R4 to a tranny man I know to rebuild it. Next week I'll be taking the 350 out and putting in the 700R4. It was the dangest thing. Riding along and just waiting/wanting it to change "one more time". I like the 700 in my 37 so good I think it spoiled me.
