1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Anyone have a copy they'd be willing to accurately scan and post?
I have armrests and new door panels for my '51 3100 but can't seem to find the template I had. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If no one responds, here is what I have done:
Cut the heads off of two attachment screws and grind a point on the head-end of the screws. Place the screws in the door leaving just a little of the point protruding outwards. Then, put the trim panel in place and push it against the screw heads. You then have marks where the holes should be made.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Great idea Tim. I will have to store that one away from when I get to that part of my resto. Thanks, Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Tim, you sir, are a genius! Thank you!  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's just what I've done in the past Tim. I've got a set of transfer screws that I inherited from me Pop, I've used them a lot in my wood working also. The advantage is you can screw them down into the hole almost flush and they are easily removed with the hex socket that comes with the set. McMaster has a set like mine and they've proven to be handy for many projects over the years. http://www.mcmaster.com/#transfer-screws/=ml7t4e DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Thanks for the link Denny, nice little tool set I would never have thought to look for or known what they were called. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I use that same technique, with different size screws, to locate the holes for the interior visors in the roof-cardboard. Perfect holes/cuts every time.
If it tight/tough screwing in/out the screws, you can cut a slot (Dremel tool) in the pointed-head and use a small flat-blade screwdriver.
I am pleased to see how much money I saved by making my own (in about 10 minutes of unskilled work).
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I like to save a buck here and there also Tim. Spotted a rack like this in one of those fancy garage tool catalogs: http://www.pbase.com/dennygraham/image/149996470I had a scrap of 2x2 angle in the corner so I punched a few holes in it. Saved about $30 from what I figure, that is if your time isn't worth any thing. DG
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I decided to go even cheaper on this one guys. I threaded the armrest screws in from the back side so they stuck out just a bit, dabbed a bit of black shoe polish on the ends, screwed the panel in place and pressed the board into into the screw ends where the armrest goes. Perfect circles.  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, Denny, I did exactly what you guys are talking about. Rounded off the head for "marking" my panels for arm rest and also this this for the sun visors. Most folks come in the shop and ask what was I doing....after I tell them they slap their heads Once I Marked my panels I used the cheapo hole punching set and bingo, perfect circles. Great minds think a like!!!
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It's just that us old dudes have been around the horn a few times Alvin and we've seen a lot of those tricks before, biggest problem I have is remembering all I've seen. By now, I've got a tool for every need, but sometimes it takes me a week or two to find it.
Denny G
| | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 |  simplicity at its finest | | |
