5 members (Guitplayer, Hambone, 3B, Otto Skorzeny, Tom McGrath), 130 guests, and 1 robot.
Topics128,084
Posts1,056,087
Members48,434
#938882 04/26/2013 9:45 PM
Ok guys I need to get my 216 rebuild and new seals done. Anybody have a good idea what something like this would cost a fella? A ruff guess would be a great help to let me know so I don't get screwed over. Thanks
brickman #938899 04/26/2013 11:52 PM
If your having it done. It could go as high as $3000.00
lots of time just hunting for the parts etc.
Same here in northern Illinois, about $3500 with the top end
completely gone over, grind crank, mod connecting rods, new
alum pistons, new cam gear.
DG
Denny G
Sandwich, IL
Ex Hall Monitor
Ex Hall Monitor
When I did mine the basic rebuild kit from Kanter was about $1200 with insert rods & shipping. The rebuilder obtained new valves & guides & charged about $1500 all done for the rebuild. I paid another shop several hundred to pull the front sheet metal then pull and re-stick the engine when done. If you get into the rockers you'll pay several hundred more.
A friend of mine had his done by a first class shop. When they went to bore they ran into rust holes from the water jacket. It then had to have sleeves. That boosted the cost way up.
1951 1 Ton Completed
Is the rebuild your only option to consider? If you source a good replacement engine you may save costs. I bought a complete project truck, 1954 3600 all disassembled for $1600 with this fresh rebuilt 54 235.
http://www.flickr.com/photos/advance-design_parts_co/8129067943/in/set-72157631867396207
I then sold off the remaining parts and made most of my money back. If you are looking for the original rebuild I get that to, just a suggestion if you have some flexability.
Cool that is the range I was figuring in my head.
add .15% contingency to it and youll feel better when done.
