0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | Ok guys I need to get my 216 rebuild and new seals done. Anybody have a good idea what something like this would cost a fella? A ruff guess would be a great help to let me know so I don't get screwed over. Thanks | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | If your having it done. It could go as high as $3000.00 lots of time just hunting for the parts etc.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Same here in northern Illinois, about $3500 with the top end completely gone over, grind crank, mod connecting rods, new alum pistons, new cam gear. DG
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | When I did mine the basic rebuild kit from Kanter was about $1200 with insert rods & shipping. The rebuilder obtained new valves & guides & charged about $1500 all done for the rebuild. I paid another shop several hundred to pull the front sheet metal then pull and re-stick the engine when done. If you get into the rockers you'll pay several hundred more.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | A friend of mine had his done by a first class shop. When they went to bore they ran into rust holes from the water jacket. It then had to have sleeves. That boosted the cost way up. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Is the rebuild your only option to consider? If you source a good replacement engine you may save costs. I bought a complete project truck, 1954 3600 all disassembled for $1600 with this fresh rebuilt 54 235. http://www.flickr.com/photos/advance-design_parts_co/8129067943/in/set-72157631867396207I then sold off the remaining parts and made most of my money back. If you are looking for the original rebuild I get that to, just a suggestion if you have some flexability. | | | | | Joined: Jan 2011 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 59 | Cool that is the range I was figuring in my head. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | Cool that is the range I was figuring in my head. add .15% contingency to it and youll feel better when done. | | |
