Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (NJC, baldeagle, carbking, 2-Ton), 31 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#939830 04/30/2013 4:16 PM
Any one here change their lock pins to have the door and handles keyed the same? Their self?
My truck came with an ign key but no door key and I'm thinking of just resetting the pins in the door tumblers to match the ign. (Anti theft dealt with separately) Looking for any tips you may have.
Give me ambiguity
or give me something else
CASO #939837 04/30/2013 4:55 PM
I did mine, I used a Frisbee so as to not loose parts, I re-arranged the tumblers to fit the key I had. Mag glass or bi-focals are a must, these are tiny parts.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
CASO #939843 04/30/2013 5:25 PM
Easy to do if you have the pins. '64 got lucky. If you have 4 that match it wouldn't hurt to leave one open.
CASO #939873 04/30/2013 7:36 PM
thanks guys, I have the equipment, and my neighbor is a locksmith so I might get lucky if I need pins. I guess I have a new project...
Give me ambiguity
CASO #939898 04/30/2013 8:58 PM
Nahhh, no luck involved charlie, truck came with a couple extra door handles I robbed for tumblers.
CASO #939911 04/30/2013 9:40 PM
There aint no stopping a good hot rodder.
CASO #940197 05/01/2013 10:57 PM
In waiting to connect with my neighbor about pins this evening a question came up.. Was there a separate key for door and ignition or were they keyed the same originally?
Give me ambiguity
CASO #940214 05/01/2013 11:46 PM
They were originally keyed the same. The door lock should have it's code on it.
CASO #940217 05/02/2013 12:00 AM
so really I should key the ign to the doors which means I still need a new key... dang
Give me ambiguity
CASO #945412 05/23/2013 11:29 PM
Yes, it is easier to re pin an ignition lock. Finding a locksmith with a code book that is over 50 years obsolete may be a problem. If you'll PM me the code number from the door I'll look up the cut to give to a locksmith.
Cletis #945493 05/24/2013 11:38 AM
PM sent
Give me ambiguity
Moderated by  ndkid275, Phak1
