2 members (Tony292, baldeagle),
37
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Any one here change their lock pins to have the door and handles keyed the same? Their self? My truck came with an ign key but no door key and I'm thinking of just resetting the pins in the door tumblers to match the ign. (Anti theft dealt with separately) Looking for any tips you may have. Thanks
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I did mine, I used a Frisbee so as to not loose parts, I re-arranged the tumblers to fit the key I had. Mag glass or bi-focals are a must, these are tiny parts. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Easy to do if you have the pins. '64 got lucky. If you have 4 that match it wouldn't hurt to leave one open. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | thanks guys, I have the equipment, and my neighbor is a locksmith so I might get lucky if I need pins. I guess I have a new project...
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Nahhh, no luck involved charlie, truck came with a couple extra door handles I robbed for tumblers. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There aint no stopping a good hot rodder. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | In waiting to connect with my neighbor about pins this evening a question came up.. Was there a separate key for door and ignition or were they keyed the same originally?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | They were originally keyed the same. The door lock should have it's code on it. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | so really I should key the ign to the doors which means I still need a new key...
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, it is easier to re pin an ignition lock. Finding a locksmith with a code book that is over 50 years obsolete may be a problem. If you'll PM me the code number from the door I'll look up the cut to give to a locksmith. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Yes, it is easier to re pin an ignition lock. Finding a locksmith with a code book that is over 50 years obsolete may be a problem. If you'll PM me the code number from the door I'll look up the cut to give to a locksmith. PM sent
