9 members (Otto Skorzeny, Gdads51, Paul Mullen, DavidBraley, TUTS 59, Ponchogl, Shaffer's1950, JoergK., mk72),
118
Mod | | | Forums66 Topics128,184 Posts1,057,196 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Now I have 1 video,(of 3) of the '58 Viking 50 L.C.f. semi-tractor. I took measurements,(outside r.f.-outside l.f,to check fender clearance difference between this truck,and the '55 5700 L.C.F.,to see if the '55 sheet-metal would "fit" the '58 frame.(71" on BOTH trucks!!) Axles are the same width! new pic's and vid's in "Photobucket"-when I can get the up-load to work correctly! got the measurements on video,of the '55 5700,but the '58 Apache 50's fail @ 99%! Hopefully later this evening??
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Sorry,guys!! I'm still waiting for "Photobucket" to up-load the '58 Viking vid's. Gets to 99%,then says up-load failed. Should have a link established in a few hours,hopefully!! Thanx.
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | My '58 Viking vid's got deleted,somehow! Will take pic's in near future. Royal PAIN!! Been working on this thing since Noon,and I SHOULD have gone FISHIN'! Too late now...Almost 6:00 P.M.! At least you guys can see the axle widths are the same for the 2 trucks. '58 Viking has 9:00X20;00 rubber,b.T.W. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Willy, I assume you want to move ALL of the sheet metal (cab and front clip) from one frame to the other... Both trucks should have the same front axle with number 3711405 forged into them. So the measurements would be the same. The parts book says 55 thru 57 share the same frame and 58/59 share the same. I've never had one of each to compart side by side, but if I did, I'd be comfirming the frame drop between the axle and bumper were the same. Any other issues can be worked out, like hole locations for the core support. Mike B  | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You might try Picturetrail. I had better liuck with it over Photobucket. | | | | | Joined: Feb 2013 Posts: 42 New Guy | | New Guy Joined: Feb 2013 Posts: 42 | Flickr.com is very easy, very elegant, professionally managed, without any of the BS advertising banner crap -- and it's free. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks for the info,Mike! The '55 sheet-metal,(front-clip/cab,need quite a bit of work,but could be done,piece-by-piece,since it'll be a frame-up,which would make it much easier to access all of the brake,steering,and suspension components,as well as a more thorough job of everything else. I may have access to a "Goodwrench" '79 350/4-bolt-main,truck engine."Crate" engine was installed, about 6-months before this truck was retired. former owner's son claims it has WAY less than 10,000 miles on it,probably closer to 5,000! Turned it over by hand,last Summer! If it wasn't for the wasps,we would've tried to get it running,but we plan on making a video,(on "Youtube"),later this Spring. Truck is 1970 Chevrolet C-50 moving van,sunk to the axles,since sitting since 1980! Thanks to "53moneypit,and Flying Zebra,as well! I'm ready to try something different. Do you know if it is possible to transfer pic's,vid's from P.B,to P.T.,Flikr? Thanks!!
