2 members (Gray_Ghost, 1 invisible),
179
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 127 Shop Shark | | Shop Shark Joined: Jan 2012 Posts: 127 | Pictures on Photobucket of 1960 2-Ton Viking. I am new to this forum and am hoping the pictures will link to Photobucket. Here is my 1960 2 Ton Viking before restoration. Will be asking the experts for help as I dig into the work.
Keep the rusty classics going.
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Welcome Dwight You want to check out the Big Bolt Forum for your Viking.
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Welcome to the Bolt! Looks like you picked up a nice truck! As Bear mentioned, there's a lot of good advice over on the Big Bolt Forum. Thanks for the pictures, and keep us posted on your progress. | | | | | Joined: Jan 2012 Posts: 127 Shop Shark | | Shop Shark Joined: Jan 2012 Posts: 127 | Thanks for the welcome and for mentioning the big truck link.....will be spending alot of time in there asking questions, and helping when I can.
| | | | | Joined: Jan 2012 Posts: 127 Shop Shark | | Shop Shark Joined: Jan 2012 Posts: 127 | Thanks for the welcome. While restoring this huge 1960 Viking 2 ton, sometimes I think I bit off more than I can chew....but I am persistent, and the restoration is coming along. Its good to preserve these classic trucks which helped America achieve its economic might of the 40s, 50s, and 60s.....those were the days. Only Ron Paul could lead America back to those years of prosperity.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Just as an aside--the powers that be here frown on political commentary. So a word to the wise......  | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Good work. That's a nice '60 you have there! | | | | | Joined: Jan 2012 Posts: 127 Shop Shark | | Shop Shark Joined: Jan 2012 Posts: 127 | Thanks Iron Clad.....at least I saved her before the leaking roof did permanent damage. Two coats of Rustoleum brown oil primer and 3 coats of Rustoleum oil paint, thinned a bit, and fine sanding between coats. Way too much time involved, but the end product was worth it.
The lady looks fine, But I could use a shine.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | That turned out really nice! In one of your captions you mentioned adding turn signals. Doesn't it have any now? If not, you should be able to put dual filament sockets in the parking lights and add them there. Beats drilling holes in your hood or fenders. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | DwightViking1960,WELCOME!! LOVE that truck! I spent many hours in one almost identical to yours,(un-restored pic's.),back in the '80's! That old 283 used more oil than gas,but fired-up in any kind of weather. Trans/vac. two-speed shifted like butter,and never ground a gear,and I drove it,using the clutch,just to start in 2nd,lo-side! Thanks for the pics! Hauled hundreds,(if not thousands), 5-7-ton loads of roofing materials,tear-off,and gravel with the old girl. I don't recall a break-down,in the 8-years I drove it! When I first got the truck started and running,it sat for 15 years,and it only needed plugs,points,and fresh gas,and a carb re-build. Bled the brakes,and replaced some lights and wiring. She was on the road again for another 20 years,until the owner retired,and the truck went to the junk-yard,where they used it for several years,as a yard "Dog". HAVE FUN!!
