| | | Forums66 Topics128,018 Posts1,055,259 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Did a search, was looking for the heater motor (12v) part number from napa, that someone posted and I can't seem to find it. Now either I'm blind or just (DeeTaDeeee).  help??? | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Thanks, less than $30.00, going to get it now | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Got new motor, now my next question is, Will the body length effect the placement inside the housing? Length of old motor body is 3.5 in., the new motor body is 4.0in EDIT: ended up being the wrong one, after two trips to NAPA, the part number for the 5/16 inch shaft 655-1020, and the number for the 1/4 inch shaft 655-1022, finally got the right one (1/4in) and it comes with a sleeve to fit 5/16 so it can be used for both.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is a good article on rebuilding one. In my recirculating heater with a 12-volt replacement I had to modify it a bit. As long as you get squirrel cage clearance and have the correct stick out into the firewall you should be ok? You certainly have room on the firewall side to absorb the 1/2" if you need to. http://www.speedprint.com/deves50/heaterrestore.php | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | This is a different model than the one I have, mine is a recirculation unit not fresh air. | | |
