Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (Gdads51, Phak1, 1955 1 Series, Otto Skorzeny, Stovebolt48, Guitplayer, Hanks custodian, 1 invisible), 47 guests, and 3 robots.
Topics128,022
Posts1,055,271
Members48,418
#938659 04/26/2013 12:54 AM
Did a search, was looking for the heater motor (12v) part number from napa, that someone posted and I can't seem to find it. Now either I'm blind or just (DeeTaDeeee). dang help???
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #938735 04/26/2013 11:42 AM
PapaJ #938770 04/26/2013 2:16 PM
Thanks, less than $30.00, going to get it now
1953 Chevy Two-Ton
PapaJ #938803 04/26/2013 4:38 PM
Got new motor, now my next question is, Will the body length effect the placement inside the housing? Length of old motor body is 3.5 in., the new motor body is 4.0in
EDIT: ended up being the wrong one, after two trips to NAPA, the part number for the 5/16 inch shaft 655-1020, and the number for the 1/4 inch shaft 655-1022, finally got the right one (1/4in) and it comes with a sleeve to fit 5/16 so it can be used for both. yahoo
1953 Chevy Two-Ton
PapaJ #939052 04/27/2013 5:56 PM
Here is a good article on rebuilding one. In my recirculating heater with a 12-volt replacement I had to modify it a bit. As long as you get squirrel cage clearance and have the correct stick out into the firewall you should be ok? You certainly have room on the firewall side to absorb the 1/2" if you need to.
http://www.speedprint.com/deves50/heaterrestore.php
This is a different model than the one I have, mine is a recirculation unit not fresh air.
1953 Chevy Two-Ton
Moderated by  ndkid275, Phak1
