0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
#937736 04/22/2013 8:17 PM
just took my original radiator to the shop for a clean and pressure test.
Question....was the radiator painted gloss? Satin or flat black in 42?
some help please
I believe it would have been satin or semi-gloss. Eastwood sells black radiator paint in a rattle can, designed to be thin so that heat transfer is not overly impaired. I have used this product and it is quite satisfactory. Regardless of what type of paint you settle on, you don't want to lay it on too thick,
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
thanks Kent, I'll add that to my eastwood order
Socket Breaker
Socket Breaker
The radiator shop won't paint it for you ?
-W
My radiator shop always sends them back painted.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
ordinarily a shop will only paint the rad when they've done real repairs to it, testing and flushing doesn't qualify
I suppose that's possible. When I take one in, it usually needs more than that! grin
Rich
1947 Loadmaster
