0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | just took my original radiator to the shop for a clean and pressure test. Question....was the radiator painted gloss? Satin or flat black in 42?
some help please | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I believe it would have been satin or semi-gloss. Eastwood sells black radiator paint in a rattle can, designed to be thin so that heat transfer is not overly impaired. I have used this product and it is quite satisfactory. Regardless of what type of paint you settle on, you don't want to lay it on too thick,
Kent | | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | thanks Kent, I'll add that to my eastwood order | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | The radiator shop won't paint it for you ?
-W | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | My radiator shop always sends them back painted. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ordinarily a shop will only paint the rad when they've done real repairs to it, testing and flushing doesn't qualify
Bill | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I suppose that's possible. When I take one in, it usually needs more than that!  | | |
