6 members (BC59, gswbbc, Hanks custodian, 55shaker, dt235sd, wilbur53), 70 guests, and 1 robot.
Topics128,048
Posts1,055,538
Members48,424
#9366 03/09/2005 8:27 PM
We all know the Eaton H0x2 axle had a long life. Over that time period, the drums were switched from smooth to finned. Does anyone know if those later finned drums are the same diameter/depth as the older smooth drums? Were there drum size differences between H052 and H072 axles? If the finned drums are deeper, will they cause tire fitment problems on a '54 if the later brake parts are retrofitted? Am I nuts for even thinking about this?
1954 GMC De Luxe COE
#9367 03/10/2005 7:27 PM
Yes, you're nuts. :p I don't the the fin issue will cause any problems. Brake sizes varied some depending on the year and the model, usually the difference was with shoe width. The distance between drum faces is usually 3.5" more on the later rear ends, part of that is the housing and part is the drum. You can slip the newer differential under your truck using newer wheels and narrow tires, but there isn't much clearance between the tire and the fender.
All I can say is get out the measuring stick.
Fred
52 3600
69 C-10
#9368 03/12/2005 6:05 AM
Fred, the fins (and the likihood of 9/16" studs)are the reason I want the later drums. I know the axle tubes are wider on the later H052s...I guess I'm just going to have to find another '67-'72 truck, steal all the brake parts, throw them onto one of my old axles, and see what happens.
#9369 03/12/2005 6:19 AM
Let us know what you learn.
Fred
52 3600
69 C-10
#9370 03/12/2005 3:37 PM
I just rebuilt the brakes on my 63 Eaton rear diff. I have a buddy that works at a Carquest parts store and he got me every part that I needed for it, including the drums. The drums are expensive though, about $140.00 each. A lot of the catalog companies also sell the brake parts but I wasn't sure what I had so I went with the local guy that would return stuff if it was wrong. As far as I know, you can still buy everything that goes inside that drum, including the drum.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#9371 03/12/2005 7:33 PM
Scott,
Can you get me the part # for the drums you got thru CarQuest? Thanks.
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#9372 03/13/2005 1:59 AM
Quote
Originally posted by mugsy:
Scott,
-David
Sorry, I don't have the boxes anymore. I see in my LMC catalog that they offer them for about $20.00 cheaper per drum but I'm sure shipping will make up the difference. I can call the guy Monday if you really want the number. What is the diameter of your drums and the width of your shoes? My set up was 11 5/32" diameter drums and 2 3/4' wide shoes for the drums I bought. Let me know,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#9373 03/13/2005 6:48 AM
Yeah Scott, mine are the same. What'd you pay per drum if you don't mind my asking?
My \'65 Chevy C-20
#9374 03/13/2005 3:52 PM
About $140.00 each,I see LMC has them for $120.00,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#9375 03/13/2005 9:46 PM
Cool, thanks.
My \'65 Chevy C-20
