| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 805 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 805 | Based on recommendations from the good folks here at "The 'Bolt", I have been running this brand in my 1955 235 c.i. since I took ownership of my truck in 2009. I am now looking to re-stock my shelves and can not find it! All I can locate is Rotella T1...has the packaging/marketing of it changed? Is it the same as what I had been using? Better? Worse? Please advise. I want and do take good care of my engine! THANKS. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | pretty much the same quality with somewhat updated formulation, things changed a few years ago concerning the zinc content, but I believe T1 still has some, shouldn't make any difference for you
Bill | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've been using the Rotella T SAE 40 in my Detroits, have had no trouble finding it at the local oil distributor or truck stop. It may have been a year or so that I last bought a case.
Grigg | | | | | Joined: Feb 2000 Posts: 5,232 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,232 | Bill's right, the oil has changed, same with non-diesel oil. It shouldn't make any difference in your application. Your engine is well broke-in by now.
Joe | | | | | Joined: Jun 2009 Posts: 805 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 805 | Thanks for the info. I just want to keep on truckin'! | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | You can run 15W-40 Shell Rotella triple T. The zinc formula has not changed in the triple T. I think the T-1 was/is a formula for Detroit Diesels.
John G 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I checked at NAPA today, the old familiar "Rotella T" is no longer available, it is now listed as T-1.
Grigg | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Joe_H posted this link in another thread. > Lubricate Classic EnginesIt discusses Lucas Hot Rod & Classic Car Motor Oil SAE 10W-40. > Lucas weights and description (No straight weights) > Lucas specs, zink, phosphorousLucas is real proud of their oil: $40/5-Qt bottle at O'Reilly. Rotella T-3 is about $18/gal, plus extra qt, at Advance Auto Parts. I couldn't find any recent ZDDP info on Rotella. Shell says that it can be used with modern emission equip. > Rotella T Triple Protection description (No straight weights) > Rotella specs- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
