| | | Forums66 Topics128,157 Posts1,056,878 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 9 New Guy | | New Guy Joined: Apr 2013 Posts: 9 | Ok so will synthetic oil eat my tranny gears? I cannot find a positive yes or no in the forums. I read somewhere g5 eats ferrous ( brass ) metals. Now,I almost took out a crown gear in a snow blower auger box with synthetic g5 once. It was a nasty mess.
So some guys here run synthetic I take it?? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | This is from the Novak transmission folks.
When filling your transmission with gear oil, we recommend that you select a conventional mineral oil or a para-synthetic in lieu of a full synthetic oil. Properly assembled manual gearboxes do not have the thermal strains seen by combustion engines or hypoid gears. Synthetic fluid in these gearboxes, while not harmful, is probably an economic waste.
Hypoid gear oil is sulphurized higher than transmission oil and can be mildly corrosive to the non-ferrous alloys used for synchros, bushings and thrust washers in these transmissions.
An 80W-90, API-GL5 or MT-1 rated fluid is very good. Some claim faster shifts from using a 50W engine oil in their transmission and we do not consider this to be contradicted unless you operate your vehicle in a very warm environment. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | We don't know what kind of or what year truck/car you're asking about but I don't believe the synthetic oil is going to hurt anything internal. I assume what you've read about is the damage to the "brass" in a manual transmission. Those concerns are with the high sulfer content of some Hypoid greases.
The one problem you may run into unless the trans is designed to use synthetics is with the syncros. The syncro rings may not grab as good with the synthetic, which can result in clashing of the gears. This is especially bad whith the SM420. I suspect it's because its gears have more mass than a 3 speed or the late model 4 and 5 speed transmissions. Give it a try, if it causes a problem shifting, drain it out and refill, all you've lost is the cost of the synthetic. Denny G
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oops, looks like Brad was up early also, ya out fumbled me again buddy while I was correcting my spelling.
DG
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...craigK, by the way, welcome to the Stovebolt Page. There are several, no many, Canadians here and maybe some close by. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I just drained and filled my transmission and everything I read recommended non-synthetic oil and recommended GL-4, so that's what I used. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Everything I read said 80w-90 gear lube. AutoZone sold me 80w-90 multi-purpose GL-5, so that's what I used. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Why was I told to use ATF in my T5? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Why was I told to use ATF in my T5? maybe it's a 'world class' version, see here, seems like ATF is what GM says Bill | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I can only wish for something called "world class" Guess I will change today. Thanks all. | | | | | Joined: Sep 2011 Posts: 1,458 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,458 | Why was I told to use ATF in my T5? T5 uses Dexron III (non synthetic) Synthetic & semi synthetic fluids can degrade may older gasket materals and some RTV sealants (as used on the T5) causing them to leak. NV4500 uses synthetic gear lube ONLY, has syncro rings with fiber surface, will eat them up if mineral oil is used. I ran a M20 (brass rings)for sevral years w/ that syn gear lube, shifted better, brass syncro seemed to grip just fine.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Apr 2013 Posts: 9 New Guy | | New Guy Joined: Apr 2013 Posts: 9 | I settled for a hydrolic / transmission cross. It is meant for tractors that run the same hydrolic as tranny fluid in a common oil pan. It will not eat brass. Then I had to fix a lot of leaks. Nothing new there. With no oil in the old one there was nothing to leak. 3 speed manual, 53 gmc. | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Synthetic GL-4 will work just fine.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I've had synthetic gear oil in my 1952 3 speed for several years and have changed it a couple times mostly just to inspect it and learned I went there unnecessarily. Never had any gear clashing issues and double clutching at speed into low to navigate rush hour works extremely well in my case.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | In a prior vehicle (48 Dodge) I tried full synthetic 85wt in the tranny. Only negative I noticed was I had to wait to downshift to first (non syncro). Prior to the synthetic, I could stop at a light and downshift from 2nd to 1st right away. With the synthetic, when first stopped, if I downshifted immediately the gears would clash - found I had to wait for several seconds to go into first. I assumed the synthetic worked so well there was still gears spinning in the gearbox. | | |
