2 members (Samantha, klhansen),
308
7
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 15 New Guy | | New Guy Joined: May 2011 Posts: 15 | Have 1950 Chev PU. Trying to complete missing stuff on doors. I have the "on door" weatherstrip ready to put on, but there's a lower door retainer required on the bottom of each door on interior side of doors. It is a narrow metal piece that is attacheh with metal screws to door panel and it is shaped to a weird config. The rubber weatherstripping carries continuously around the door and across the bottom of door and it is glued in place. Does anybody know what that retainer is for and how it interacts with weatherstripping? Where does it sit in relation to weatherstripping? I like the trim piece as it adds a finished look, but don't see it's purpose and how it mates to seal.
BTW, I don't see screw holes at the bottom of my door. Was this strip even used on 1950 year trucks?
I also have a nasty rattle only with window down inside door somewhere as I accelerate faster. What are the anti rattle window seals and where do they go in door? Will that typically resolve issue? Are these seals called something else as I can't find them in any parts supplier as anti-rattle seals.
1950 Chevy 3100 5-Window 1946 Chevy Panel 3/4 Ton
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | If you're referring to the fuzzy strips that run along the bottom of the window opening I've heard them called a number of things, fuzzies, cat whiskers, beltline felts, etc.. I believe the "correct" name is window sweep that could vary as well. Most vendors will know what you're referring to.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | This should answer your question on placement. Somebody may have filled the holes, they are small. And yes 1950 trucks came with the retainer. http://www.oldchevytrucks.com/blog/index.php/?p=626 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | This is my 52 panel. Maybe this helps to go along with Brads. Also, a serch will probably turn up a good bit of stuff. I think Denny G. has some pics to. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Bottomwindlacemetalstrips003.jpghttp://i140.photobucket.com/albums/r19/LutherParris/52Panel/Bottomwindlacemetalstrips004.jpgEDIT: when the piece is installed correctly you will notice a small "cup" effect in the weatherstipping and you can see where it fits to the body and makes a seal... to keep out wind/water/noise ect. I will admit most trucks I see this piece is missing and most weather stripping missing on the bottom or just glued back on. A couple of my holes were "big" so I stepped up a size on a couple of the screws but you really can't tell it on mine. Hope this helps.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I also have a nasty rattle only with window down inside door somewhere as I accelerate faster. What are the anti rattle window seals and where do they go in door? Will that typically resolve issue? Are these seals called something else as I can't find them in any parts supplier as anti-rattle seals. Your 50 should have a fuzzy attached here ...pic... I got a replacement from truck shop in orange Counterparts brand It's part of a kit Your rattle with the window down could be the regulator. Check o see if your leather rollers are intact. Good luck | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | |
