0 members (),
284
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | On the 57 GMC 370 LCF. Just rebuilt everything on the brakes. I had a nice tubing bender, so I bought brake lines in the closest lengths possible, already made up. I started buying the steel ones from a local parts store. They were just galvanized looking steel lines. As I progressed on, I needed some more lengths. It was more convienent this time to go to NAPA. The ones they gave me were coated with some kind of paint. Now I have great brakes but I have leaks at most of the steel color ones. The fitting does not want to spin on the line to tighten up. The whole line wants to turn. The colored lines from NAPA have no leaks at all. Sure do hate to have to replace all those other lines again. (sigh)
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Haven't had that particular problem with new lines. I've used both plain steel lines from advanced auto and painted or coated from NAPA. Leaks I've had a few. I've had old lines twist in two with nut frozen to line. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I haven't had that problem before either, not with new lines. What does the parts store you got them from say about the problem? | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I have not contacted them about the problem, didn't expect much of an answer from them. I have sprayed the fittings with brake cleaner, and the leak comes from between the nut and the line. Therefore it seems the flare is not seating. I have re-tightened as much as I dare, without cracking the brass fittings. Do you think maybe screw the line fitting all way off, and put a light coat of grease on the nut where it seats on the flare, and re-tighten?
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | When I buy lines at O'reillys I have to be REAL CAREFULL not to get METRIC. They look the same and the tags are sometimes missing. Some are color coded and some are not. Just mentioning that in case that is the problem. Like threads on like threads don't leak. Flare is different on Metric.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Maybe thats the problem, I will go back and check with them to make sure. These had green tags on them, but actually I did not read them. The threads seemed to run easy on the old fittings. Thanks for the tip.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | One has to be very careful because just about all European and Asian brake line fittings are metric and since 1980 some domestic use metric and some imperial. There are some metric that are slightly smaller than imperial and screw in too easy. To complicate matters, many parts counter people are no help what soever in this matter. To complicate matters even more NPT threads are the same in the US as well as Europe. A 1/2" pipe thread is the same on both sides of the water. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I seem to remember green is metric.!!! Only buy the tagged/marked lines with proper SAE threads delineated. People bring the unused lines back and they get mixed up. I buy a whole bunch of lengths and take back the ones I don't use.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks for the tips,guys!! I'll be doin' a whole brake up-grade,later this Spring,including ALL the rubber and steel lines. This topic just saved me a BUNCH of TIME AND HEADACHE!! Hope your problem can be remedied,easily,OLD G.M.C. GOLD!! Best of luck!! | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Well I did go back and check. He swears these are not metric and nothing on the green tag says anything except 1/4" OD. He said he had been selling this same line for years and no problems. Mine had a green tag on the line and the nut was steel colored also. He showed me his metric lines and they did have a GREEN nut, but a purple tag on the line, and did say 10mm. Soooo back to square one.....Guess if the film of grease don't work, I will replace them all with NAPA. By the way, I don't even know what brand name his store is. It just goes by: City Auto Parts. He does have access to Cardone brake parts. Thanks to all.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I did have trouble with the green protective coating. For some reason I sanded on them, "gooed" it up and the nut would not rotate and so on. Took them back for new ones and didn't touch the coating. Worked well. Do you have leaks at where the City Auto Parts line meets Napa line? Could be the Napa coated ones. Anyway, you do have to retighten sometimes to stop leaks. Just don't mess with that coating or it will contaminate the threads and it will "goo" into space between nut and tube. It's not just paint, it's epoxy coating or plastic coating or ?? Take a known SAE male and female thread with you to test each end of each piece you buy.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not pushing any store but the first thing I'd do is visit another store.... any new lines I've seen for a while should say on the tags exactly what they are. Should say if its "standard SAE thread or metric. Shop around before you really screw something up. Brake lines are cheap.
...had a rusted, leaking line on my step son's Dodge pickup. I bought some line and a fitting. Doggone, the new line would work in the union joining them but the original end on the truck would not...CLOSE but no cigars. Turns out the union was the culprit. ...listen to crenwelge, he said a mouth full. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i would look at both type of lines side by side and look at how the flares are flared and are they squared. they should be the same. if they are then maybe its the fitting you are attaching them to  ive seen dorked up inverted flare fitting from a not so good tubig job earlier in the trucks life. ive used both type of lines and had no issues yet. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | No, I would not say Im having problems where the City Auto meets the NAPA. It's where the lines screw into the original brass fittings. It had a bunch of different types of brass and banjo bolts. I cleaned all the original fittings good and ran a fitting from one of the old brake lines in them to clean the threads. The NAPA lines do not leak where joining the original brass fittings, but some of the City lines do. Thanks to all.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | I have found easy bend line from napa works quite well it's about twice the price of regular line but is guaranteed not to rust. I comes in 50 foot rolls just bend and flare my own ends with new ends from napa | | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | Can you burnish the fitting in by un tighten and re tighten the fittings 3 times. Sometimes this will help seat the fitting. If that doesn't work you probably have a seat angle mismatch.
